Run As Wpilib Java Deploy does nothing
When I select 'Run As|Wpilib Java Deploy" from the menu nothing happens. I was able to install eclipse the FRC update suite and I was able to install Java on the robot all without issue. I can bring up the driver station and see that I am connected, but when I try to deploy the code nothing happens. no error, no nothing. Any help is appreciated....
Scott |
Re: Run As Wpilib Java Deploy does nothing
I had the same issue, and I solved it by uninstalling Eclipse Mars, and reinstalling the C++ version of Eclipse Luna from here.
After that, just follow the instructions again in the setup documentation. |
So we installed Luna, but the Eclipse Java Developer Tools does not appear to be available for it anymore. So we are stuck again. Any idea how to get it? Can we just use the Java IDE instead of the C++ version?
Scott |
To install the tools, you should go to Help -> Install New Software, and type "Luna" in the search box and click the recommended link that pops up. If nothing appears after a while, try unchecking the box that says "Show only the latest versions of available software". When the items for download load, open the tab that says "Programming Languages" and scroll down to Eclipse Java Development Tools. Check the newest version's box and click next. Take the defaults on all options and let it install. Restart the IDE and you're good to continue in the documentation steps. The WPI tool installation should be the same process regardless of whether you are using Luna or Mars. |
So I installed the C++ version. When I attempt to find and install the Java Developer Tools under the available software it just says Pending forever no matter what options I select.
Scott |
If it still didn't work, try unchecking the button that says "Contact all update sites".
#7
Okay so the conclusion was that you cannot deploy with MARS. You need to run Luna. We had success with the 32bit version of Luna. Installing the 'Eclipse Java Developer Tools' and FRC plugins from Luna took more than an hour. They ran extremely slow, but just be patient and they will eventually finish. I found that I could download eclipse from here much faster than from the eclipse.org site:
http://ftp.acc.umu.se/mirror/eclipse...ease/luna/SR2/ |
