Go to Post This is about more than building a robot, we cannot only do the fun things. If you are fully involved than you will be prepared to do anything in life. - Andy Brockway [more]
Unread 07-09-2015, 15:36
ScottRandallWay ScottRandallWay is offline
FRC #2543
ScottRandallWay is an unknown quantity at this point
Run As Wpilib Java Deploy does nothing
When I select 'Run As|Wpilib Java Deploy" from the menu nothing happens. I was able to install eclipse the FRC update suite and I was able to install Java on the robot all without issue. I can bring up the driver station and see that I am connected, but when I try to deploy the code nothing happens. no error, no nothing. Any help is appreciated....
Scott
Unread 07-09-2015, 19:07
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
Re: Run As Wpilib Java Deploy does nothing
I had the same issue, and I solved it by uninstalling Eclipse Mars, and reinstalling the C++ version of Eclipse Luna from here.
After that, just follow the instructions again in the setup documentation.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 07-09-2015, 21:42
FRC #2543
So we installed Luna, but the Eclipse Java Developer Tools does not appear to be available for it anymore. So we are stuck again. Any idea how to get it? Can we just use the Java IDE instead of the C++ version?
Scott
Unread 07-09-2015, 22:56
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Scott
In the documentation it says not to use the Java version, but to use the C++ version, no matter which language you use.
To install the tools, you should go to Help -> Install New Software, and type "Luna" in the search box and click the recommended link that pops up. If nothing appears after a while, try unchecking the box that says "Show only the latest versions of available software".
When the items for download load, open the tab that says "Programming Languages" and scroll down to Eclipse Java Development Tools. Check the newest version's box and click next. Take the defaults on all options and let it install. Restart the IDE and you're good to continue in the documentation steps.
The WPI tool installation should be the same process regardless of whether you are using Luna or Mars.
My FRC History:
Unread 08-09-2015, 00:09
FRC #2543
So I installed the C++ version. When I attempt to find and install the Java Developer Tools under the available software it just says Pending forever no matter what options I select.
Scott
Unread 08-09-2015, 00:36
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
If it still didn't work, try unchecking the button that says "Contact all update sites".
My FRC History:
Unread 08-09-2015, 12:14
FRC #2543
Okay so the conclusion was that you cannot deploy with MARS. You need to run Luna. We had success with the 32bit version of Luna. Installing the 'Eclipse Java Developer Tools' and FRC plugins from Luna took more than an hour. They ran extremely slow, but just be patient and they will eventually finish. I found that I could download eclipse from here much faster than from the eclipse.org site:
http://ftp.acc.umu.se/mirror/eclipse...ease/luna/SR2/
