Go to Post It is crucial to keep experience and keeping collected under pressure as high points that can't be measured in a test. - jnelly [more]
Unread 17-01-2002, 19:50
Alan Ing Alan Ing is offline
None #0368 (Kika Mana)
Alan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond repute
I would imagine, that it wouldn't be legal as it would defeat a safety device, but even if you could, remember that when a circuit breaker trips, it places the lever inbetween the on and off state. You then need to move the lever completely into the off state and back in to the on state which is a double motion after the fact that you have lost your power.
20 amp fuses for Spikes Andrew Schuetze Electrical 8 01-04-2003 22:18
60Amp Circuit Breaker Mounting "Experience" archiver 2001 0 23-06-2002 23:57
Blowing Relay Fuses archiver 2000 2 23-06-2002 21:57
Triping Timed Fuses Joe Canavan Electrical 2 21-02-2002 09:34
Internal Fuses (PTC Resistors) on Window Motors bigqueue Technical Discussion 6 08-02-2002 21:34
