Go to Post Difficult? Yeah. Extremely difficult? Some parts. Doable? It's been done. - [more]
Unread 09-09-2015, 17:13
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Strange build error!
Hello All,
I am having a strange error when building robot files (any other programs seem to work).
This is the error message I receive
BUILD FAILED
Unable to find a javac compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK.
It is currently set to "C:\Program Files (x86)\Java\jre1.8.0_51"
Note that I am using the run as deploy button to build the code, despite not being connected to a robot.
Anyone have an idea what's going on?
Thanks!
Unread 09-09-2015, 20:11
orangelight's Avatar
orangelight orangelight is offline
AKA: Alex
FRC #0548 (Robostangs)
orangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to behold
Re: Strange build error!
Take a look at this thread
Unread 10-09-2015, 18:53
AKA: Ahad Bawany
no team (None)
Even following the steps listed in that thread did not help
Unread 10-09-2015, 20:41
AKA: Alex
Does it still give you the same error?
Unread 10-09-2015, 21:03
AKA: Ahad Bawany
no team (None)
Actually, this is really strange. I just updated windows, and it now works. Wonder if Windows 10 was just not playing nice with eclipse...
Unread 15-09-2015, 01:31
justAdev justAdev is offline
FRC #0004
justAdev is an unknown quantity at this point
Hello All,
Thanks!
I've ran into this problem many times and luckily I knew how to fix it every time it popped up
First make sure you have Java installed.
If you're sure you have it installed, assuming you're using windows, follow these steps:
  1. Click the start button
  2. Then right click computer
  3. Click Properties
  4. Click Advanced System Settings
  5. Click Environment Variables
  6. If you see JAVA_HOME, go to step 11, if not, click new
  7. Variable Name = JAVA_HOME
  8. Variable Value = <Location of your Java JDK> Without the <> (Usually something like C:\Program Files\Java\jdk1.8.0_25")
  9. Click Ok
  10. Restart Eclipse and You're Done!
  11. Click JAVA_HOME
  12. Click Edit
  13. Set variable value = <Location of your Java JDK> Without the <> (Usually something like "C:\Program Files\Java\jdk1.8.0_25")
  14. Click Ok
  15. Restart Eclipse and You're Done!
I hope I could help
Unread 24-09-2015, 21:05
SamcFuchs's Avatar
SamcFuchs SamcFuchs is offline
Programmer
AKA: Sam Fuchs
FRC #0236 (TechnoTicks)
SamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud of
  3. Click Properties
  9. Click Ok
  11. Click JAVA_HOME
  12. Click Edit
  14. Click Ok
I hope I could help
This is what worked for me way back when I had that problem iirc. Also, I don't think it's win10. I've got win10 and no problems.
Sam Fuchs
236 TechnoTicks, Old Lyme, CT
2015 - Programming, Electrical
2016 - Lead Programmer, Co-Driver
2017 - Lead Programmer, Co-Driver
