Go to Post Don't fight bureaucratic morons... embrace them! Humour and publicity will take care of the rest. - dtengineering [more]
Unread 11-09-2015, 01:24
obsunal obsunal is offline
FRC #4191
obsunal is an unknown quantity at this point
Driving 2 robots at the same time
Hi,
I'm not sure if this is the right section, but I think it fits. Apologizes in advance.
We would like to drive two robot at the same time but we can't connect both at the same time, because both radios are 4191. If I go into modem interface and change ssid will it work? If not how can we make make both robots work?
Edit: Sorry for title.
Unread 11-09-2015, 01:27
Re: Driving 2 motors at the same time
In theory, yes. In practice, it may be slightly more difficult.
I am not an expert at this, but I believe that you actually need to change the IP address of one of the radios (and changing the SSID would also be a good idea). Try using 1914 (your number, in reverse).
Unread 11-09-2015, 01:28
Changing the SSID to give each robot a unique name is the usual way to do it, and it works fine.
(There's another option, but it isn't reasonable unless you have a dedicated wireless access point and the robot routers are configured to bridge to it.)
Unread 11-09-2015, 01:30
PikaDotus's Avatar
PikaDotus PikaDotus is offline
CEO
FRC #3501
PikaDotus is an unknown quantity at this point
There are three places to change your team number.
  1. Use the FRC Bridge Configuration Tool to reprogram one of your radios to have a different team number (doesn't matter what it is, just keep the radio off when near other teams!)
  2. In Eclipse, go to Preferences > WPILib Preferences and change your team number to whichever radio you want to deploy to.
  3. On your driver station, open the settings section and change your team number to the team number of whichever radio you want to run using that computer.
Final thing: make sure you're connected to the right wifi network for the robot that you want to deploy to / run.
Technical debt is investing in the present using the future as collateral.
Unread 11-09-2015, 02:39
FRC #4191
Can you tell more about bridge thing? We have one spare radio. I could use as bridges and access point.
Unread 11-09-2015, 06:03
EmileH's Avatar
EmileH EmileH is offline
#dontbelarge
AKA: Emile Hamwey
FRC #1058 (The PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Another step (1.1) You also need to reflash your roborio with the new team number in addition to all the above steps. You can use the RoboRio imaging utility that came in the 2015 FRC software update to do this.
2016-present: High School Student, FRC 1058 PVC Pirates
Unread 11-09-2015, 09:39
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Here is a thread that talks about how to do this. Read Greg's posts in particular.
Running each robot on a separate SSID is probably the easiest. The typical non-event way to this is use the robot radio as an AP & set the SSID there. make sure the DHCP is turned on in the AP. (For the roborio class bots). Connect the DS computer to the robot you want to drive.
For the Roborios. You can go into the configuration web page and change the MDNS name there. Easier than doing all the other stuff.
