Re: Bearings vs Bearing Blocks
I'm assuming the issue here was too small of a sprocket.
Tension is the force applied to a member in the direction that will cause it to expand. In this case, it refers to the force applied by the sprockets to the chain when there is no work being done (usually no motion at all). Chain tension is rarely measured directly, but estimated by pushing transverse on the midddle of the chain run and watching the "rebound". Just like the string on a musical instrument, a chain under more tension will be harder to displace, will return more quickly to the center, and will oscillate more quickly. Usually we just make sure it feels right; most of us grew up with bicycles and know what a properly tensioned chain feels like. Note that the required at-rest tension does depend on the load tension, and also the length of the runs. If you want to see how well you are tensioned, the real test is to put the chain under peak load and watch the loose side of the chain (the return to the drive gearbox). If its motions don't make you worry about the chain ratcheting or jumping off, you should be good.
As I indicated above, at a minimum, the stationary tension in the chain should be more than half the tension differential needed to turn the sprockets at peak load; otherwise the back side will go completely slack under load. * - and if it isn't, the chain is definitely too loose! |
After thinking about this a bit... If you are ratcheting a chain drive, you have a design issue. The issue might be using too light of a chain to meet another design goal such as weight. Engineering is about trade offs after all. A couple of chain drives designs to think about that don't ratchet despite the high loads:
Bicycles especially full suspension bicycles. The slack side has a relatively light tension from the rear derailleur. Relatively light side loading will move the chain from sprocket to sprocket. Motorcycles: You actually set a chain deflection so at rest the chain has no tension. This is needed because the C-C distance changes with suspension travel. |
#7
I've heard of teams that do c-c that just replace entire chain runs if the chain gets too loose. Other than cost and having to keep track of old vs new chain, I don't see much wrong with that approach. While I've never done it, I've heard c-c for 35 chain is much easier. I imagine the chain's much greater load capacity reduces the effect of wear, not to mention the smaller number of links for the same length. But I really think 35 chain is overkill in most applications, you're just throwing weight away. Last edited by Chris is me : 14-09-2015 at 17:59. |
#8
Vex and Andymark have it for $1/ft, so it's a very valid approach price wise.
#9
My previous team has done that. It is pretty easy to tell an old chain loop from a new one. The side deflection on a used chain is significantly more than on a new one.
