Go to Post The top 3 debates you don't want to bring up in a group of nerds: Mac vs PC vs Linux, Best Programming Language, and Best CAD Program. - EricH [more]
Unread 15-09-2015, 21:03
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
pic: WCD 3 CIM PTO Ball Shifter Render
Unread 15-09-2015, 21:04
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: pic: WCD 3 CIM PTO Ball Shifter Render
Very nice. PTO/shifter for 2.2lbs is really good.
Is there any way to change the gearing to get a free speed under 18fps? Going above 20fps free speeds seems sketchy with 4 cims.
Unread 15-09-2015, 21:14
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
I think it is a 6 cim drivetrain. I think it's hidden behind the rest of the gear box.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 15-09-2015, 21:20
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Originally Posted by orangemoore View Post
I think it is a 6 com drivetrain. I think it's hidden behind the rest of the gear box.
I continue to amaze myself with my idiocy. Whoops.
Thank you.
In any case, you can't accelerate with 6 cims to above 20fps with the roboRIO anyway without a brownout, especially a low voltage, so is it possible to reduce the gearing for that?
Unread 15-09-2015, 22:07
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Thank you.
Yes, the gearbox shifts, ball shifters based on the subject line, though the mechanism isn't stated. Low gear is around 7:1 (see first post), so with three CIMs per side, you can easily get up to enough speed for the shift, which can then take you to 20 fps.
Given the voltage brownout levels, I now expect that PTOs are much less useful than they may have been in the past. The first roboRIO year with bumpers, defense, or crazy acceleration requirements will likely be the proof/disproof on this point. The bottim line is that the additional weight for shifting may completely override the weight for separate motors, especially for lower-resource teams.
Added:
Originally Posted by R.C. View Post
I'm unsure how PTO's are less useful, as they just power another system. I would say 3 CIM drives will be less useful with the brownouts.
Yes, and that's why. The reason PTOs have been so useful in the past is that the tightest resource limitation was motor count. This promoted using the same motors for multiple functions. Now, the biggest limitation is the current draw, as in order to keep the motors running, you can't let the voltage drop. Unless the PTO, including the switching hardware and shafts/chains to get the power to where you need it are significantly lighter than the motor and controller, there isn't as much benefit.
Unread 15-09-2015, 22:15
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
R.C.
MadTown Robotics Team 1323
Unread 15-09-2015, 22:21
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
I'm aware that it shifts, however, the acceleration/current may still be too high for safety even if you start from low gear. Probably need to test that to be sure, because I have no idea, honestly. You'd also need to implement autoshifting for that to work.
The weight cost is on the order of a pound or two for a PTO if you go with the WCP PTO (plus whatever you're using for integration into the system). The alternative for endgame mechanisms is to use discrete motors or pneumatics, both of which usually cost more weight for similar outputs although they are easier and faster to integrate. Of course, the last endgame was in 2013, so maybe they're gone for good (and with them most of the use of PTOs).
Unread 16-09-2015, 03:24
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
The slowest the gearbox can be configured without significant plate changes is 7.1 ft/s in low and 17.9 ft/s in high (80% of free speed)
Thank you.
This is all interesting conversation, and thank you all for your replies. However, it would be particularly useful if someone could post a personal testament to how the roboRio responds to having a 6 CIM drive train. This way I could walk the new CAD student through the process of reevaluating the gear ratios with some real evidence. Unless that happens, this project will continue to be a test of the new control system's outer limits, as it was originally intended to be.
Hopefully with this gearbox, we will be know what is too fast, so that when next season comes we will be able to pick appropriate speeds.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 16-09-2015, 08:35
Knufire Knufire is offline
Instead of anecdotal evidence, how about some objective data?
http://www.chiefdelphi.com/media/papers/3067
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 16-09-2015, 15:39
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Thank you for posting that. I don't know how I missed it.
The data presented in cyber blue's testing papers is concerning in some ways, but not in others. For instance, it is concerning that their test platform that is geared for 11 ft/s dropped it's voltage so close to the brownout point, but their testing also shows me that this gearbox will probable not have trouble with tripping the breaker, or causing a brownout while in low gear.
From the thread you just linked:
We only did this specific test with the 4 CIM configuration because with 6 CIMs or 4+2 we just spun the wheels.
Unread 16-09-2015, 16:55
Chris is me's Avatar
AKA: Pinecone
So back to the actual gearbox...
I think your CIMs aren't supported as well as they could be. It's pretty common in these kind of gearboxes to have a web that follows the diameter of the CIM in order to support the whole face. Right now the little sliver of metal supporting the middle of the CIM may not be substantial / rigid enough. The tiny amount of weight savings isn't really worth risking flex in that area of the gearbox.
If that is a stock ballshifter shaft, I would be concerned about direct driving a wheel off of that shaft. It might not be a good idea to load the shaft that way. The hex end of it is just pressed in to the end of the shifter shaft, with about 3/4" of engagement if memory serves. I think this is one reason the COTS direct drive ballshifters have a third gear stage. This does indeed make fitting a ballshifter into a WCD gearbox in 2 stages quite difficult.
I'm working on a similar gearbox for a similar application, and the constraint of using the ball shifter shaft without direct driving off of it is quite annoying. I don't know how feasible this is at all, but have you considered using it backwards? Having the CIMs drive a gear on the output of the shifter shaft, then putting two output gears on the wheel shaft? Might be worth a shot, particularly if you're into the latest WCD fad of hanging your drive motors over the wheels. Probably not a good idea, but something unique to look at.
Unread 16-09-2015, 17:20
The newest rev of the ball shifter shaft has the hex pinned instead of pressed.
Unread 16-09-2015, 17:41
Aren_Hill's Avatar
Build Nifty Things
Pinned AND Pressed.
-Aren
A guy who likes robots.
Unread 16-09-2015, 18:25
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Originally Posted by Aren_Hill View Post
Pinned AND Pressed.
-Aren
Thank you two for clarifying. However, I am not planning on using the vex shifter shaft.
Thank you bringing up the question of CIM support. I think your concern is stemming from the fact that there are several aspects of this gearbox that are not easily visible from this angle.
1. The CIM is resting against 0.25" Al along its entire bottom edge.
2. nestled in between the CIM motors are standoffs that run back to support the pneumatic cylinder that runs the PTO. These standoffs will also help support the CIM motor from below.
For this reason, I have never been a fan of the design of the ball shifter shaft from vex. In this design there are two custom simplified one piece shifter shafts.
This is a cool idea in my opinion, Even though it would cause a few problems. The only issues I see with it right now are that it would make gearbox assembly difficult, and cause there to be an unused gap in the gearbox unless the first stage was cantilevered.
Unread 16-09-2015, 23:32
Whoops, that was actually the wrong paper. Here's the complete testing they did: http://www.chiefdelphi.com/media/papers/3071
