Go to Post Those kids are different! They seem more mature, respectful, and intelligent than most adults. They can actually think instead of just spitting out facts. They are obviously getting a real education. - Amber H. [more]
Unread 17-09-2015, 19:03
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
What happens to commands when disabled?
I'm programming a robot using the command-based template, and have a few questions about what happens to commands when the robot is disabled.
When disabled, do running commands get cancelled, continue to run without driving motors, or pause and resume running when the robot reenables?
Similarly, do JoystickButtons and Triggers continue to poll and run commands while disabled?
Thanks for the help.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 17-09-2015, 22:21
Re: What happens to commands when disabled?
Answer to what a command does when the robot is disabled is in the Javadoc for one of the methods of the Command class: http://first.wpi.edu/FRC/roborio/rel...f269d3ec63faa8
As long as you have a call to run the Scheduler in DisabledPeriodic it will cancel any commands that you haven't run the above method on, run the commands you have (without motors moving) and continue to poll any OI stuff you have mapped and schedule appropriate commands (assuming they are set to run when disabled).
Unread 18-09-2015, 10:29
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
One tactic, if the documentation doesn't completely answer your questions, is to create a new test Robot project, and put debug statements in interesting places. Then load the test project on the roboRIO, run it, and see what happens in different modes.
For 3081, we often will create a standalone project that tests a particular set of functionality, then copy the code into the main robot project when it's working well enough.
I have a directory on my development machine that is filled with little test programs (non-robotics) that do this very thing, built up over the years.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 18-09-2015, 11:04
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The FPGA disables the outputs that can control physical action on disable. All the inputs and DS IO are processed as normal. Rather or not your loops executes depends your code. Smart dashboard IO depends on having your loops running in disable. See post 1.
