Go to Post Just keep doing. Everything. Keep designing, keep building, keep learning, keep fundraising. Build more robots, try more ideas, compete more and more and more. - [more]
Unread 20-09-2015, 22:42
seamushroom seamushroom is offline
AKA: Seamus
FRC #2491 (No Mythic)
Team Role: CAD
seamushroom is an unknown quantity at this point
pic: Diagonal View
Unread 20-09-2015, 22:48
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Re: pic: Diagonal View
Correct me if I am wrong, but this looks like a passive wheel with and encoder attached to it. So when you move it tracks the distance. I assume that you would use two of these on a robot, one in an x axis and one in the y axis (assuming you are looking at the field from above).
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 21-09-2015, 11:58
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Great job with the CAD work. I can critique the design a bit:
You're going to have all kinds of trouble with the sliding link. A good rule of thumb for sliding joints is that the ratio between bearing length (in the direction of sliding), and bearing diameter (or spacing) should be greater than 2:1, otherwise when one side starts to grip a bit, the whole bearing will twist and jam. You've got hardly any bearing length in this sketch, so jamming would be a real concern.
Another good rule of thumb is to prefer rotating joints to sliding joints - so if you can redesign this to use a trailing arm, you'll have more chance of success.
Unread 21-09-2015, 13:22
dougwilliams's Avatar
dougwilliams dougwilliams is offline
Engineer - Controls, Electronics
FRC #2053 (TigerTronics)
dougwilliams is on a distinguished road
Is the plan to rely on the weight of the wheel to keep the wheel in constant contact with the ground? I was looking for some sort of spring device for that purpose. Even without binding as noted by nuclearnerd, I would be concerned with it "skipping" and sliding along the wheel direction rather than rotating.
But it is a nice design, our team had considered some way of using a tracking wheel for measurement last year and didn't go through with it. We were accurate enough on Mecanum wheels, and timing alone (with gyro angle corrections) to do a 3-stack autonomous.
