Go to Post The only tool that will work to get our robot done in time will be a prayer rug. - Rick TYler [more]
Unread 18-09-2015, 21:25
Gearheads1 Gearheads1 is online now
AKA: Brian Holmgren
FRC #4455 (The Burger Bots)
Gearheads1 is an unknown quantity at this point
[FTC]: Tank Treads
We are new to FTC and think that there may be a place for tank treads in this game. Have any FTC teams used tank treads from Tetrix, or do they tear up the field? Thanks in advance for your help.
Unread 19-09-2015, 11:49
dcribbs dcribbs is offline
AKA: Dave Cribbs
FTC #5598 (Parish Robotics)
dcribbs has a spectacular aura aboutdcribbs has a spectacular aura about
Re: [FTC]: Tank Treads
Some of our teams have used tank treads in the past for various reasons. They do not tear up the field. The robot in the video (6635) would shudder a bit when turning due to the tank treads high grip.
The most challenging part is putting the rubber treads in the individual links.
Dave Cribbs
Coach & Teacher
FTC - Team 5598, 6635, 6795
FRC - Team 3626
Unread 19-09-2015, 18:23
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
In six years of FTC we have never done a treaded tank drive design before.
We have done 4-wheel omni, 3-wheel omni with triple-wheeled axles (Kiwi), and mecanum wheels twice, so we are not afraid to experiment with different drive types that best match up with the game.
We are this year still considering a customized treaded tank drive with cleats added on to snag the bars. The issue is with ;atera; swing friction. when turning
As far as the TETRIX plastic tread, goes I would not trust it under high loads, especially lateral loads.
My current thinking is to Have a very light bot and consider using a narrow ~1" timing belt driving a pair of close axle spacing inboard wheels on each side, and have omni wheels sandwiched on either side of the belts at front and rear, to reduce the turning drag,
With just the right amount of center drop on the central wheels, this could improve turning while allowing bot to roll along mostly up on the tops of the bars.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 19-09-2015, 19:02
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Generally treaded drives have to be protected from lateral loads-- Tetrix treads are the same way, with the added restriction that they're pretty light duty.
If you're still interested in a treaded robot but don't want the difficulties of a fully treaded robot, you could try making a half-treaded robot-- ie, an 8-inch contact patch in the back of your robot and some omni wheels in the front.
I would also recommend looking at FTC 5975's Treadpods from last year. I was judging at North Super Regional last season and these were easily the coolest things I saw there.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 20-09-2015, 22:17
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Could you use a double sided timing belt for tank treads?
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 20-09-2015, 22:56
AKA: Nick Aarestad
Or just single sided. In 2012 FRC 1816 did this with their robot, Zephyr. You could almost certainly get away with something similar on an FTC robot.
tumblr | twitter
VEXU UMN (2015-??)
Unread 21-09-2015, 01:44
REVving up for a new season
FRC #2848 (All-sparks)
This is one of the things that we we are playing with also.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 21-09-2015, 09:18
AKA: Brian Holmgren
Thanks for the great discussion! It's nice to have options! Best wishes for a great season!
Unread 21-09-2015, 14:37
Munchskull's Avatar
Team Role: CAD
Where can you buy doubles sided time belts for cheap?
Also what would be the recommendation for the with?
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 21-09-2015, 14:45
AKA: Nick Aarestad
SDP-SI sells double sided timing belts in metric and imperial sizes. I would recommend metric, as you'll have more choices. You're looking under Timing Belts.
I'm looking at maybe doubling up 9mm belts, but you could also try 15mm or something thinner. You're looking at $20-$100 per tread depending on width and length of the belt.
tumblr | twitter
VEXU UMN (2015-??)
Unread 22-09-2015, 08:36
Gdeaver Gdeaver is offline
FRC #1640
Monday night we took our summer practice bot and put some Tetrix tank treads on it. It was an ugly violent climb up the mountain but it did work. Need to make several geometry changes. Robot drives terrible on the floor. Good night in proof of concept but, a long way to go.
http://wiki.team1640.com/index.php?t...14_150921a.jpg
Unread 22-09-2015, 12:07
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
DavisDad will become famous soon enoughDavisDad will become famous soon enough
Originally Posted by Gdeaver View Post
Monday night we took our summer practice bot and put some Tetrix tank treads on it...
Thanks for sharing your work, and the photo!
Unread 22-09-2015, 18:02
Sasha Sasha is offline
AKA: Alexander Kirillov
FTC #4137 (IslandBots)
Sasha is just really niceSasha is just really niceSasha is just really niceSasha is just really niceSasha is just really nice
We also put some tetrix tread on the robot. It climbed the inclined surface OK; didn't have time for test driving on the floor yet. Will test more next time. Meanwhile, here is the photo:
https://www.facebook.com/islandbots/...type=1&theater
FTC 4137 "Islandbots"
islandbots.org
Unread 23-09-2015, 00:45
Munchskull's Avatar
Team Role: CAD
Do you think a center drop would improve its ability to drive on the floor without compromising it's mountain climing?
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 07-10-2015, 09:45
Coach Seb's Avatar
Coach Seb Coach Seb is offline
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
So any update on using the Tetrix tank treads ? We got our first prototype last night and because we did not have the rubber insert, we could not climb the ramp... just placed the order today and hopefully it will help !
https://www.facebook.com/groups/1433...group_activity
Coach Seb
FTC 9819 RoboRats
