Go to Post just remember, with power comes responsibility. - Mike Ciance [more]
Unread 20-09-2015, 19:56
seamushroom seamushroom is offline
AKA: Seamus
FRC #2491 (No Mythic)
Team Role: CAD
seamushroom is an unknown quantity at this point
pic: Top View
Unread 20-09-2015, 19:57
Knufire Knufire is offline
Re: pic: Top View
Why a VEX omni wheel? For a follower wheel carrying minimal torque, it seems like it's rather overkill.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 20-09-2015, 20:42
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: Top View
I don't see that a third follower wheel parallel to the other two would give you any additional information. In particular, if your robot strafes (I'm guessing that you're using a skid-steer and that would only happen if you're rammed or otherwise lose lateral traction), you wouldn't know about it. A third wheel with a different orientation would. Useful orientations for three wheels would be delta (kiwi), H, I, and U. A Y configuration would tell you about strafe, but not report rotation.
Edit: Re-reading your description, perhaps you do have what I would call an "I" configuration. My initial reading of "each end of the robot" was left/right, and I thought you were doing differential to get rotation. I now believe that you mean "front/rear", and are orienting those transverse to forward travel.
Unread 20-09-2015, 23:47
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Re: pic: Top View
If your are using them for what I am assuming (trying to calculate the robot's position on the field) then good luck. You will probably need it. Even with good encoders the error in measurements (of distance and rotation) will quickly build up and throw off your data. Plus everything is easy until you account for turning in a WCD, then there are about a billion other factors to account for. I will be very happily surprised if you get it working well and will most likely grovel at your feet.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 21-09-2015, 01:14
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Re: pic: Top View
I agree with Ari, it seems like a very odd way to gather data. Giving the benefit of the doubt that it will work then it seems like it will be a rather heavy answer to gathering directional data. Assuming west coast drive, I would personally use one encoder per side and a quality IMU to track the acceleration, position and rotation of your robot. I have to had it to you though, it is a rather creative solutions for data gathering. Reminds me of how a ball mouse works.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 21-09-2015, 10:42
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
Re: pic: Top View
Dumb question; Why not put an encoder in the gearbox[es]?
Unread 21-09-2015, 10:54
saikiranra's Avatar
saikiranra saikiranra is offline
UCI
AKA: Saikiran Ramanan
FRC #3476 (Code Orange)
saikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond repute
Re: pic: Top View
Having two of these modules perpendicular to each other help see if wheels are slipping or how far a robot has traveled if an opponent is pushing it sideways.
2014 - Current: Team 3476 Electronics, Programming, and Scouting Mentor
2011 - 2014: Team 696 Student and Drive Coach
Unread 21-09-2015, 10:57
Re: pic: Top View
I'm surprised at the reactions in this thread, I had always thought that follower wheels were a way to get more accurate odometery than encoders in gearboxes.
The problem with encoders on your drive wheels in a skid steer drive is, well, the fact it's a skid steer drive. You're relying on wheel slip to turn, which means your encoders are going to read farther than they do.
With two follower omni wheels (perpendicular to each other, one facing forward), the wheel will (theoretically) only spin while moving forward and slip, but not rotate, when you move sideways.
I know 33 had spring loaded follower wheels in 2014.
Unread 21-09-2015, 17:12
Darkseer54's Avatar
Darkseer54 Darkseer54 is online now
Former Controls Captain and Driver
AKA: Zach Kaplan
FRC #1086 (Blue Cheese)
Darkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of light
Re: pic: Top View
Originally Posted by Knufire View Post
I'm surprised at the reactions in this thread, I had always thought that follower wheels were a way to get more accurate odometer than encoders in gearboxes.
I have also seen plenty of teams get success in this. If you look at 488's octocanum they use this type of follower wheel. It seems to be a tested method, so not sure what the sudden uproar against it is...
2014: IRI on a losing record.
Unread 21-09-2015, 17:49
Munchskull's Avatar
Team Role: CAD
Re: pic: Top View
I was not aware that this had been tried before. If this is a bonafide method then I would love to know more. Could some one explane the requirements a little more?
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 21-09-2015, 18:22
Darkseer54's Avatar
AKA: Zach Kaplan
Re: pic: Top View
Originally Posted by Munchskull View Post
I was not aware that this had been tried before. If this is a bonafide method then I would love to know more. Could some one explain the requirements a little more?
Did a search for follower wheel, the way that most teams reach success with it seems to be that they use two of them for translation in combination with a gyro for rotation. Though this is used for omnidirectional drives, so I am unsure pf the effectiveness on standard skid steer. It would also help for drives such as 4 omni's which have a tendency to drift.
Unread 21-09-2015, 20:46
Re: pic: Top View
A follower wheel is a common thing, in certain drive systems. (So common that, contrary to popular belief, Lunacy wheels were NOT the only thing allowed to contact the regolith--follower wheels were specifically allowed.)
But, as noted, the standard configuration is two, at right angles, with a gyro for rotation, and usually not on a skid steer (Lunacy being the exception).
And, for some teams, an IMU is even more preferred: two accelerometers at right angles to each other and a gyro. Just needs some calculus.
BTW, a more common configuration of a given follower wheel--and a simpler one, I think--is a small wheel (like a VEX omni, and not a VEXPro omni)on the end of a rotating support structure, slightly spring-loaded so it'll stay in contact with the ground.
Unread 21-09-2015, 23:10
Doug Frisk's Avatar
Doug Frisk Doug Frisk is offline
Keeping Score
AKA: Doug Frisk
Doug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond repute
Re: pic: Top View
Out of curiosity, has anyone ever attempted to modify an optical mouse to do movement tracking for an FRC robot?
Something like this: http://hackaday.com/2013/04/03/addin...omous-vehicle/
I would think that it should be very inexpensive parts wise and should track well on carpet.
Though it would get a bit more complex if you wanted the device to not be in physical contact with the field.
Unread 21-09-2015, 23:37
Munchskull's Avatar
Team Role: CAD
Re: pic: Top View
Back in 2005 (I think) my team tried this but with a ball mouse. It worked till the robot went to fast for the sensor.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 22-09-2015, 00:55
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: pic: Top View
and just make your robot drive like a mouse ball like technokats (45) used to do!!
http://www.chiefdelphi.com/media/img...c6cf6b31_l.jpg
