Go to Post You can't lose if you submit an animation. Even if you don't win an award, your team wins by just doing it. - David Brinza [more]
Unread 21-09-2015, 20:33
entertainr entertainr is offline
Build Addicted
AKA: Levi
FRC #4522 (Team SCREAM)
entertainr is an unknown quantity at this point
Talon SRX Encoder Signal Processing Trouble
Recently my team has decided to switch to Talon SRX controllers. I've been moving slowly towards working with the PID controls on them, but I have a problem. Whenever I run the motors forward, the encoder counts backwards. When I run the motors in reverse, the encoder counts up. The CTR Reference Manual labels this as a problem if I want to use the closed loop features. I have attempted to use the SetReference.vi as suggested in the manual with no success. I am using a Grayhill 63R 256 count digital encoder. The wiring has been done correctly from the Grayhill to the breakout board.
http://www.grayhill.com/assets/1/7/Opt_Encoder_63R.pdf
ID:	19300  Click image for larger version
Name:	Periodic Tasks.PNG
ID:	19301  Click image for larger version
Unread 22-09-2015, 00:03
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Re: Talon SRX Encoder Signal Processing Trouble
Can you check the self test to see if the reverse-setting is taking effect (see screenshot in Section 7.4. Reversing sensor direction, best practices.). Is the Selected Sensor Pos the inverse or equal to the Quad Pos?
Be sure enable the robot (even briefly) to allow settings to pass into Talon. See Section 16.2 for details.
Unread 22-09-2015, 00:06
ozrien's Avatar
Omar Zrien
AKA: Omar
I just noticed your third screenshot. Pull out "Sensor Position" from the "unbundle by name" object instead of "Quad Position". Section 16.9 explains it better, but "Sensor Position" is what is used in the internal closed-loop.
Unread 22-09-2015, 11:22
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
A hardware fix: It is a little messy but you could swap the A & B input wires? I prefer to fix thing like this in software & leave the hardware standard, but there are other view points.
Unread 22-09-2015, 16:54
Build Addicted
AKA: Levi
That might work, and if worse comes to worst I'm willing to try it. I would prefer to know how to fix it in the software though, especially considering there is a function made specifically for this, and it will be much easier to solve if we come across this problem again.
Unread 22-09-2015, 21:17
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
(For completeness-) Or switch the motor leads.
FRC 766, 2015-, Mentor
Unread 24-09-2015, 11:56
Build Addicted
AKA: Levi
I finally found the problem this morning.
My original problem was that I didn't know the Talon Set Reference vi doesn't come with a Talon Send vi inside of it, and you need the Send vi to save any changes, such as the Reverse Feedback Sensor setting.
In some of my earlier attempts to fix this issue on my own, I placed a SetReference in disabled to try and update the value outside of Begin.vi. It didn't work when I set it to true and I didn't know why. I found out later when Omar Zrien pointed out Section 21.20 of the CTR Software Manual to me, but at that time, I thought setting the value to false might fix it somehow. It didn't, so I promptly forgot about it and let it sit as a false constant.
While working with Omar, I learned about Section 21.20, so I added the Talon Send vi in the Set Reference vi and placed it in Teleop to constantly update the value. I noticed something was fighting it, as if there was another value being sent to it (Hello Disabled!). I did a search, found my chunk of code in Disabled, and quickly removed it.
Another redeployment confirmed that my problem was solved. Thanks so much to everyone for helping out, and special thanks to Omar Zrien for working directly with me to figure it out!
