Go to Post if sleep is essential, then yeah, I'm in trouble. - Eria4044 [more]
Unread 20-09-2015, 21:36
CoachC's Avatar
CoachC CoachC is offline
AKA: Jim Cetnarowski
FRC #5247 (Red Devil Robotics)
Rookie Year: 2015
CoachC is an unknown quantity at this point
Move Labeview to a New laptop
Finally dumping the 2GoPC. Looking for advice on moving Labview to newly purchased laptop (Windows 10) Thanks in advance.
Unread 20-09-2015, 22:37
orangemoore orangemoore is online now
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: Move Labeview to a New laptop
Just re-download it onto the new laptop and move all team-made files/programs needed to your new laptop.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 21-09-2015, 08:51
When you move a LabVIEW project, make sure its target path in the settings gets changed to match the new location. Otherwise you will probably get "file permission" errors when you try to build it, which really means it can't find the original folder that it came from.
Unread 21-09-2015, 21:27
CoachC's Avatar
Rookie Year: 2015
Thank you both for your help. Should I be concerned with licensing agreements? Granted its for the same Team but Im not sure if the software license is per team or device.
Unread 21-09-2015, 21:34
AKA: Roger Moore
TO my knowledge you can download it to as many computers as you want. We currently have it on at least 5 different computers without any problems. So I think you should be just fine.
Although someone from NI probably could give you the official answer.
Stronghold
Student 2013-2016
Unread 21-09-2015, 22:25
The license is time limited and intended for team use. We ask that you not run a factory, do medical experiments, or control a nuclear reactor.
Putting it on a new team laptop is certainly inbounds.
Greg McKaskle
Unread 22-09-2015, 09:08
Guess I have to switch to solar panels...
