Re: Dynamically Linked Libraries
Although it may be possible (and it really isn't that hard), I'd highly recommend just statically linking everything. If you dynamically link, you run the risk of running with inconsistent versions of libraries, or having to maintain binary compatibility between libraries. It ends up being easier to just deploy statically linked binaries if RAM and HD aren't an issue, which they aren't. We deploy static binaries both at work and for robotics, and it has saved us many times.
The great advantage of shared libraries is that there is only one copy in physical memory, hard to see that as an issue in FRC since there is only one user application running in user space (besides the system and NI daemons). |
An example of that... (i.e. an issue in FRC when multiple instances occur due to a static library setup)... would be if someone wishes to use SmartDashboard... I had SmartDashboard in its own library as static... in my win32 environment, and had multiple DLLs in use. Network Tables must have only one instance to work properly... so I had to make a DLL version of it to work correctly... luckily this was all win32 environment so it was easy to do. For the eclipse environment if something similar needed to be done (which I couldn't see happening, but could if all vision processing was done on roboRIO)... The static library solution may not work... in which case the one project multi folder technique may give the best results... so far I've been leaning towards that as a workflow. I'm going to thank Jeff Downs for that suggestion from his workflow tips on the eclipse old cRIO solution. It gives the benefit for shared libraries, while allowing code to be separate... built time is still very fast too. |
Yep, I am just experimenting with stuff in my free time, seeing what I can do. The purpose of this was to see if I could dynamically load the c++ compiled code into a DLL so that I can tweak values without having to kill the running program. I have the main FRCUserProgram running code that applies only to all the hardware related aspects. This code stores all the necessary memory which is then passed into the dll every iteration. If the dll should change, the same memory is pushed into the new dll and it operates upon the memory as I intended the change to. I think this is called live loop editing.
Our robot code is split up into a bunch of processes (each is a separate binary). There is 1 process which has WPILib built into it and interfaces to the hardware. The other processes have our control loops, joystick code, autonomous mode, etc. They all communicate via a shared memory mechanism we designed. The really cool part is that this lets us re-start the various modules and replace them without taking the rest of the code down or restart it. We've been able to do things like deploy new joystick code while the driver was driving. |
How did you implement the shared memory? We noticed that POSIX message queues are not in the kernel. Is the POSIX shared memory API supported? Or maybe SystemV style shared memory? Or did you do something custom? TIA |
#7
Essentially SystemV shared memory, though we just use the mmap call directly to map a file from /dev/shm/ in. We then built up message queues with mutexes, condition variables, etc in that memory and use those. That lets you use priority inversion safe mutexes, which is good.
#8
Just putting this out there, thank you all for all your help. I have successful dynamic loading of code and am able to make changes to the program while the robot is active.
