Go to Post "Is it possible to cut enough holes in the robot to weight reduce 8 lbs?" - ScoutingNerd175 [more]
Unread 20-09-2015, 17:37
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Need assistance uploading code to Github.
Hey,
I've been trying to upload my code to a github repo, so I can work on it from school. Despite getting some help from another team through CD, I am still confused how to do this. I can figure out how to upload my code to a .git file on my pc, but I have no idea how to upload that to the repo on the github website.
If any additional info is needed for you to help, please ask!
Thanks!
Unread 20-09-2015, 21:15
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: Need assistance uploading code to Github.
https://git-scm.com/book/en/v1/Getting-Started
Start there
All opinions are my own.
Unread 22-09-2015, 01:10
ShortCircuit908's Avatar
ShortCircuit908 ShortCircuit908 is offline
King of Hacky Fixes
AKA: Caleb Milligan
FRC #4450 (Olympia Robotics Federation)
ShortCircuit908 is an unknown quantity at this point
Simple guide using Git bash:
  1. Navigate to your workspace using the 'cd' command
  2. Code:
    git init
    (Creates an empty repository)
  3. Code:
    git remote add origin <SSH clone URL>
    (Adds the remote repository as 'origin.' <SSH clone URL> is the URL given to you by GitHub, resembilng git@github.com:Username/RepositoryName.git
  4. Code:
    git add -A
    (Adds current files to the repository)
  5. Code:
    git commit -am 'Initial commit'
    (Creates a commit with added files)
  6. Code:
    git push origin master
    (Pushes local commits to the remote repository)
It is recommended that you have a decent .gitignore file in the root directory of your workspace, in order to keep unnecessary files out of the repository. A good example of a .gitignore file can be found here.
Unread 22-09-2015, 14:05
AKA: Joel Gallant
Please take the time to actually understand git before using it with other people. Don't just copy paste commands from guides online.
Unread 23-09-2015, 11:42
AKA: Ahad Bawany
no team (None)
I am currently reading your guide to learn how to properly use Git, thanks!
Sorry if it appears like I'm in a rush, this code does need to be uploaded fast. (Currently going to upload the code, and then work on properly learning git)
EDIT: Managed to post the code to our repo! I'm continuing to learn git as I go on, but at least I can work on robot code from anywhere now
Unread 24-09-2015, 21:02
SamcFuchs's Avatar
SamcFuchs SamcFuchs is offline
Programmer
AKA: Sam Fuchs
FRC #0236 (TechnoTicks)
SamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud of
In terms of .gitignore, you can pretty much just use the /dist/ file. You don't really need anything else.
Sam Fuchs
236 TechnoTicks, Old Lyme, CT
2015 - Programming, Electrical
2016 - Lead Programmer, Co-Driver
2017 - Lead Programmer, Co-Driver
Unread 24-09-2015, 21:16
We use:
/bin/
sysProps.xml
/build/
/dist/
Unread 27-09-2015, 18:04
SamcFuchs's Avatar
Programmer
AKA: Sam Fuchs
Originally Posted by Joe Ross View Post
We use:
/bin/
sysProps.xml
/build/
/dist/
Yeah, looking back, I didn't think that reply through. Here's a .gitignore that I like. It leaves pretty much only the src.
https://github.com/team236/2016-prac...ter/.gitignore
Unread 28-09-2015, 23:26
King of Hacky Fixes
AKA: Caleb Milligan
You shouldn't need to ignore .xml files. In fact, you shouldn't, especially if your project uses a framework such as Maven, which is based off xml files, or if your project uses an XML properties file.
