Go to Post "You fogot the gears!!!!" - The_Gman [more]
Unread 23-09-2015, 22:55
dmorewood's Avatar
dmorewood dmorewood is offline
Lead Designer / Coach
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
dmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nice
1/2" Hex Shaft Bevel Gears
I'm working on a go cart with a swerve drive in the offseason with a couple of friends. We aim to have this driving at 20 MPH by FIRST competition season. Unfortunately we can't find 1/2 Inch Hex Shaft Bevel Gears anywhere. If anyone knows of a good place to find these it would be a huge help.
Unread 23-09-2015, 23:01
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: 1/2" Hex Shaft Bevel Gears
Hex Shafting is relatively unique to FRC. You're much more likely to find keyed bevel gears in this size. Or, you can broach your own. Getting a good arbor press and broach is a great investment for an FRC team.
Unread 23-09-2015, 23:07
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
You can try using a 1/2'' hex broach instead. It's not a bad investment, the broach will end up being useful later anyways.
Wow, that's pretty fast for FRC. You're not using CIMs, are you?
Unread 23-09-2015, 23:11
Chris Endres Chris Endres is offline
Play hard, Work harder
AKA: Topher
no team (WildStang)
Team Role: CAD
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
Over the summer, I did an extensive search for bevel/miter gears with .5" hex bore, couldn't find anything. It's not an industry standard, so they really aren't in demand.
You can find bevel and miter gears at SDP-SI: http://www.sdp-si.com/eStore/CoverPg/Gears.htm
You can also get bevel/miter gears from McMaster: http://www.mcmaster.com/#bevel-gears/=z2kqn1
Vex pro has 15t miter gears with a 3/8 hex bore: http://www.vexrobotics.com/vexpro/mo.../217-3344.html
But as Joe said, you'd either need to used the keyed bore, or broach your own.
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
Unread 23-09-2015, 23:40
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
You will probably need to broach your own. The only hex bore miter gear I know of is the Vex one. I would go with their 3/8" hex bore gears and have a reduction to the wheels to reduce the load on them.
SDP-SI sells 1/2" bore bevel gears, all you'd need to do is buy a hex broach and broach them. They also sell 12mm bore bevel gears (as does QTCgear), which you can bore out to 1/2" on a lathe relatively easily.
How much are you planning to spend on this? Swerve drives, even simple ones, are quite expensive.
Unread 24-09-2015, 07:22
dmorewood's Avatar
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
I'm prepared to spend 500-800 dollars on the swerve modules. I found a 1/2 Inch Hex Broach on McMaster. Any suggestions for a good bevel gear to broach?
Unread 24-09-2015, 09:28
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
I had good results with these from boston gear.
461 Westside Boiler Invasion
45 Technokats
Unread 24-09-2015, 17:15
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
I would recommend going with gears from Martin Sprocket and Gear over those from Boston Gear. The Martin gears are case hardened and will wear better with heavy use. You can find their catalog here http://www.martinsprocket.com/docs/d....pdf?sfvrsn=14 and look up the part numbers at any number of suppliers to find the gears to buy.
Unread 25-09-2015, 00:23
TheHolyHades1 TheHolyHades1 is offline
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
You might want to see if it's possible to increase your budget. I've BOM'd a few swerve designs of mine, as well as looked at a few from teams like 1640 (who provide excellent resources in their swerve central), and I wasn't able to make the cost go under about $200 for each module. You'll also want to take into account manufacturing expenses, which can either be nearly free (tooling) or very expensive depending on how much outsourcing you're doing, and how much that'll cost you. Also, don't forget to budget for an extra module or two as things are likely to break ...
Unread 26-09-2015, 17:54
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
I'd worry that case hardened gears would be hard to broach, however. Some teams have used non-hardened gears and then hardened them themselves afterwards.
Unread 28-09-2015, 15:24
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Assuming there are 4 modules!
This is a go-kart which presumably won't get into a pushing match. Seems perfect for a 3-pod design, and eliminates the need for a perfect frame/suspension setup.
Unread 28-09-2015, 15:50
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
...We aim to have this driving at 20 MPH by FIRST competition season....
I'd like to be the second person to say just how absurdly fast that is for an FRC robot. To be clear you're not converting incorrectly, 20 mph is 29 fps. I'm not aware of anyone that's tried gearing for 29 fps, but I doubt anyone has successfully. It'd take most FRC robots (assuming ~120lbs) far too long to accelerate to be practical. As I recall our team's 'Speed Racer' in 2008 was geared for a free speed of 19fps, which was hard enough to drive... and was on a robot that generally turned rather than stopped... and the robot weighed around 50 pounds with battery (so it could accelerate very quickly).
I suspect something geared for a free speed of more like 14-20 fps would be much more well-suited for a game with demands for a high top speed.
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 28-09-2015, 15:55
You're assuming this is for an FRC robot.
Unfortunately for that assumption, it's for a go-kart.
