Go to Post At one of the registration days at the beginning of the year I actually made a sign saying: "I'm not smart isn't an excuse". - Mr. Pockets [more]
Unread 29-09-2015, 08:39
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
pic: Tiki Techs - FRC 2015 Robot
Unread 29-09-2015, 08:43
trumpthero786's Avatar
trumpthero786 trumpthero786 is offline
What Part of the Sandwich Are You?
AKA: Humza
FRC #2729 (Storm Robotics)
Team Role: Electrical
Rookie Year: 2015
trumpthero786 will become famous soon enough
Re: pic: Tiki Techs - FRC 2015 Robot
That's a good looking robot! Love the lights. Nothing like being able to easily spot your robot in a match. Do you guys use Arduino to control them? We use it for our LEDs.
CLAP CLAP WHOOSH!
2015 - Hatboro Horsham - Quarterfinalist with 272 and 5181 - Entrepreneurship Award
2015 - Seneca - Quarterfinalist with 316 and 5684 - Engineering Inspiration Award
2015 - MAR Championships - 50th Seed - Quarterfinalists with teams 1923 and 11
2016 - Hatboro Horsham - Team Spirit Award
2016 - Seneca - Gracious Professionalism Award
"nice beaver tail"
Unread 30-09-2015, 19:15
TikiTech's Avatar
Mr. H
Mahalo.. (thank you)
We have used the Arduino with RGB LED’s from Super Bright LED’s with success in prior years.
Last year we went with an easier design.
We picked up some LED systems from Costco (Sylvania Mosaic flexible LED light kit) that were IR controlled.
Here is an example http://www.amazon.com/Sylvania-72344.../dp/B008COVFUA
Was very easy to install, just cut off the wall wart since it runs at 12vdc. We also removed the IR receiver and put it on a connector so we could remove it for competitions. In the pit we would plug the receiver back in and change colors and other effects as needed. We ran a few separate strings in various locations. One location was the electronics area that was setup separately. Not only did it look nice but we were able to use the system to have nice bright white light when changing batteries and leave the rest of the robot colored for show.. Judges just loved to talk with the students about the robot and watch the lighting change remotely. Was fun to see what combinations the Judges and other visitors would come up with.
More than likely we will return to using the Arduino setup this year. We also have LED arrows and various customizable boards for making custom LED setups. Hope the game this year will facilitate its use..
Looking forward to another great season,
Aloha!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Division TBD | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 30-09-2015, 19:25
EDesbiens's Avatar
EDesbiens EDesbiens is offline
Passionate crackpot
AKA: Étienne Desbiens
FRC #5859 (i)
EDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of light
What are the rules concerning arduinos and other micro-controllers? And can we connect them to the Robot-Rio to communicate?
Lisa: Players play and managers manage.
Ralph: Do alligators alligate?
Unread 30-09-2015, 19:27
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Yes, but they cannot have anything to do with actuation. IE no PWM/relay/can/etc control over motors.
They can collect sensor data (such as camera or otherwise) and perform computation to offload roboRIO resources though.
Unread 30-09-2015, 19:31
I am Dave! Yognaut
AKA: Brian Bray
Originally Posted by 2015 manual 4.8-R44
CUSTOM CIRCUITS shall not directly alter the power pathways between the ROBOT battery, PDP, motor controllers, relays,
motors and actuators (per R18), pneumatic solenoid valves, or other elements of the ROBOT control system (items explicitly mentioned in R55). Custom high impedance voltage monitoring or low impedance current monitoring circuitry connected to the
ROBOT’S electrical system is acceptable, if the effect on the ROBOT outputs is inconsequential.
An arduino/equiv is considered a custom circuit.
Obligatory "this year's rules aren't necessarily next year's" but this rule has been in here for a while.
Unread 30-09-2015, 19:34
EDesbiens's Avatar
Passionate crackpot
FRC #5859 (i)
Cool, thanks, didn't know about the sensor part... So we can connect the outpout and input pins of a micro-controller to the robot-rio? And is it simple to program?
Unread 30-09-2015, 21:25
I am Dave! Yognaut
AKA: Brian Bray
I have exactly zero experience programming these things. I'd imagine it would be easier to communicate via the USB port or ethernet (or perhaps even CAN), though there is no reason the DIO wouldn't be allowed
Usually teams use independent boards for vision processing. Normal sensors usually take only a tiny fraction of CPU power. Also note that if you are using a Talon SRX with CAN, sensors can be plugged into the breakout board for the motor controllers (which may be in a more convenient location [like our tether-bot this year]) and the roboRIO can read those sensors over the CAN line
Unread 30-09-2015, 21:33
EDesbiens's Avatar
Passionate crackpot
FRC #5859 (i)
Oh, didn't know we could plug sensors on can... That's pretty cool actually Thanks guys! I'll start working on that!
Unread 30-09-2015, 22:41
logank013's Avatar
logank013 logank013 is offline
System.out.println("Ready!");
AKA: Logan Kreisher
FRC #0234 (Cyber Blue)
Team Role: Scout
Rookie Year: 2015
logank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant future
At one point, we considered outing LEDs on using an Arduino. Unfortunately, we never had extra weight. (I'm pretty sure all of our weigh ins were 119-120 pounds at every competition). Either way, awesome looking bot. It takes talent to make a robot. It takes craftmanship to make a robot look pretty. It takes a lot of both to get both results. Good work.
Cyber Blue Season 2015
IN Indy District Chairman's Award Winner | IN Kokomo District Event Winner (With 135 and 3865)
IN Purdue District Event Winner (With 1024 and 2197) | IN District Championship Winner (With 1024 and 292)
WORLDS:
Archimedes Rank 3 After Quals. | Alliance #3 Captain
Archimedes Division Semi-Finalist (With 503,188, and 836)
Scouting is life. Excel is friend, not foe.
