Go to Post If you want to attach a name to your post then I might actually consider your opinion. - Gregor [more]
Unread 17-09-2015, 17:40
dvanvoorst dvanvoorst is offline
FRC #2771 (Code Red)
dvanvoorst is an unknown quantity at this point
[FTC]: Scan not seeing Core Device Interface Module
I seem to be having trouble getting the Modern Robotics Core Device Interface Module (the one for hooking up sensors) to be recognized. I have it plugged into the Power Distribution via USB and it lights up. But when I scan for devices it doesn't show up. I assume that it should so that I can give the sensors names. I've tried a second module and it did not work either. Motor controllers and servo controllers are all working.
What am I missing?
Thanks!
Dale
Unread 17-09-2015, 22:03
Re: [FTC]: Scan not seeing Core Device Interface Module
I needed to update my ftc sdk.
Unread 24-09-2015, 15:58
BillMyers BillMyers is offline
FTC #9378 (Kalani Robotics)
BillMyers is an unknown quantity at this point
More details please. I didn't know it needed to be updated. How do you do that? What changed?
Unread 29-09-2015, 11:18
stepen stepen is offline
Junior Member
stepen is an unknown quantity at this point
okay
