Go to Post FIRST rocks, thats for sure. - Dan Richardson [more]
Unread 29-09-2015, 20:20
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Encoders for 1/2" Output Shaft
I'm wondering if anybody knows of non-optical encoders that can be mounted on a Gem 500 output shaft which is 1/2" in diameter?
Unread 29-09-2015, 20:30
Knufire Knufire is offline
Re: Encoders for 1/2" Output Shaft
I belive the end of the shaft is tapped for 1/4-20, correct? You could try sitcking a 1/4-20 bolt in the end with a shoulder and running many of the 1/4" through-shaft encoders on the bolt.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 29-09-2015, 20:44
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
That's an awesome idea except the way we currently have things set up we would have to route the wires around a wheel that we are direct driving.
Unread 29-09-2015, 21:18
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
I've been looking for one as well, perhaps for use on hex shaft.
So far I've found that the easiest thing to do is to put one earlier in the drivetrain, such as on the face of the CIMs, the gearbox shafts, or the ends of shafts.
EDIT: Why non-optical?
Unread 29-09-2015, 21:31
Gdeaver Gdeaver is offline
FRC #1640
http://www.chiefdelphi.com/media/papers/3165
Our team is working on using this encoder on our swerve.
Unread 29-09-2015, 21:32
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
It may not be the neatest solution, but you could use a 1/2" to 1/4" shaft coupler and a short length of 1/4" shaft/bolt.
A bit neater would be to machine (mostly lathe work) a bit of 3/4" shaft to have a 1/2" hole with set screw on one side and a 1/4" (or other useful size) shaft on the other.
And unless you can find an encoder that will do this, the neatest of all is to machine the 1/2" shaft down to the appropriate size, though it would have to be done during build season assuming the fabrication schedule and rules are similar to recent years.
If you only need a few counts per revolution of the shaft, you could paint the shaft with black and white stripes and use a reflective counter.
Unread 29-09-2015, 22:39
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Mounting the encoder directly on the cim output shaft was our first solution, but if you aren't familiar the the Gem 500 gearbox, the way the cim is mounted makes it hard/impossible to effectively space it out to fit the encoder in. I'd also be worried about spacing out the motor because I'm not sure how the shaft would react with the gear at very end of it at stall torque.
The logic behind avoiding optical is that this is for the NASA Robotic Mining Competition and it gets very dusty when mining. So we would be penalized for lack of dust tolerance as well as possibly having problems with the encoders in dusty conditions.
Unread 29-09-2015, 22:47
AdamHeard's Avatar
Lead Mentor
Embedding a quadrature output magnetic gear tooth sensor like 2363 (and 3847) did with a versaplanet might be an option.
Or give up some shaft length and do it entirely external on the shaft close to the output bearing.
Unread 29-09-2015, 23:51
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
You might be able to modify the GEM in a similar manner, or attach a gear to the output shaft and use a similar mod.
Unread 30-09-2015, 07:37
FRC #1640
Take a few minutes and read that paper, then download the data sheet. This sensor packs allot in a small package and can solve the tough quadrature encoder apps. We have the sensors and will be implementing them on our swerve drive. 8.00$ plus shipping, some caps and resistors and cable.
Unread 30-09-2015, 08:05
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Wow this is a crazy awesome solution! Thanks Adam!
