Go to Post You only really ever need 2 things in your tool box: A Hammer to separate things that shouldn't be together, and Duct Tape to put things together that shouldn't be apart. - Dave_222 [more]
Unread 30-09-2015, 13:07
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: FRC Blog - KOP Drive System Opt Out
Originally Posted by BBray_T1296 View Post
Kind of!?!
don't say it!
1 CIM 2K16 CONFIRMED!
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 30-09-2015, 13:09
EDesbiens's Avatar
EDesbiens EDesbiens is offline
Passionate crackpot
AKA: Étienne Desbiens
FRC #5859 (i)
EDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of light
More like NO MOTOR YEAR 2K16 CONFIRMED!
Lisa: Players play and managers manage.
Ralph: Do alligators alligate?
Unread 30-09-2015, 13:14
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
All robot movements must be powered by internal combustion engines!
Can you imagine building a small internal combustion engine for every motor on your robot? The robot would weigh 1000 lbs. Sounds like torture.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 30-09-2015, 13:17
EDesbiens's Avatar
Passionate crackpot
FRC #5859 (i)
I was more thinking that all movements must be powered by springs or gravity...
Unread 30-09-2015, 13:19
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
I certainly appreciate the flexibility we have with the KOP. The KOP team and FIRST have done a great job evolving the kit over the last few years.
That said, we are opting out of the KOP drive train for the first time as we are completing our first off-season custom drive train and expect good results from it.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 30-09-2015, 14:06
Aren Siekmeier's Avatar
Aren Siekmeier Aren Siekmeier is online now
on walkabout
  • Features are designed such that they enable a team to execute basic elements of game play.
Does the design need to be different somehow? The rail profiles look the same as last year, particularly the same low clearance, so I don't expect any substantial terrain...
Unread 30-09-2015, 14:08
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Note that the AM14U2 was designed to use more than one diameter wheel, and while it was supplied with 4" wheels last year, it may be supplied with a different diameter (6" or even 8") for 2016.
Unread 30-09-2015, 14:23
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
For comparison, here's the profile drawings for the AM14U2. I don't see any differences.
http://www.usfirst.org/sites/default...Comparison.pdf
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
Unread 30-09-2015, 19:11
EricH EricH is online now
Actually, I don't think so. Try the R/C aircraft (or R/C car) shop nearest you--they might have some nitromethane engines (or diesel engines). Ah, the smell of nitromethane in the morning... I think I could easily find a few dozen engines and mufflers and come in under 50 lbs.
Unfortunately, starting those things can be a tad tricky... stand back... and they only spin one direction, so you'll need to gear 'em.
Unread 02-12-2015, 12:25
Generator of Entropy
FRC #2973 (The Mad Rockers)
I haven't been able to find where it says when the AndyMark PDV will be available to use in an order, I thought last year it was sometime in December. Has anyone seen a date?
Unread 01-10-2015, 09:33
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Not necessarlily. I built many a control wire plane with Cox engines as a kid...http://coxengines.ca/
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
