Go to Post We are all on a big team named FIRST - Al Skierkiewicz [more]
Unread 30-09-2015, 19:11
Re: FRC Blog - KOP Drive System Opt Out
Originally Posted by Ari423 View Post
All robot movements must be powered by internal combustion engines!
Can you imagine building a small internal combustion engine for every motor on your robot? The robot would weigh 1000 lbs. Sounds like torture.
Actually, I don't think so. Try the R/C aircraft (or R/C car) shop nearest you--they might have some nitromethane engines (or diesel engines). Ah, the smell of nitromethane in the morning... I think I could easily find a few dozen engines and mufflers and come in under 50 lbs.
Unfortunately, starting those things can be a tad tricky... stand back... and they only spin one direction, so you'll need to gear 'em.
Unread 01-10-2015, 09:33
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Not necessarlily. I built many a control wire plane with Cox engines as a kid...http://coxengines.ca/
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 02-12-2015, 12:25
Generator of Entropy
FRC #2973 (The Mad Rockers)
I haven't been able to find where it says when the AndyMark PDV will be available to use in an order, I thought last year it was sometime in December. Has anyone seen a date?
