Go to Post Inaccurate data is not data. It's guessing. - George1902 [more]
Unread 01-10-2015, 13:57
xcountry413 xcountry413 is offline
FRC #2022
xcountry413 is an unknown quantity at this point
Code Not Uploading to Bot
I'm a new programmer for my team and am having trouble uploading code to the bot. The output of the program is:
run:
java.lang.ExceptionInInitializerError
Caused by: edu.wpi.first.wpilibj.util.BaseSystemNotInitializedException: The Interface for the HLUsageReporting was never set.
	at edu.wpi.first.wpilibj.HLUsageReporting.reportScheduler(HLUsageReporting.java:21)
	at edu.wpi.first.wpilibj.command.Scheduler.<init>(Scheduler.java:92)
	at edu.wpi.first.wpilibj.command.Scheduler.getInstance(Scheduler.java:48)
	at edu.wpi.first.wpilibj.command.Subsystem.<init>(Subsystem.java:60)
	at org.usfirst.frc.team2022.robot.subsystems.TankDriveSubsystem.<init>(TankDriveSubsystem.java:21)
	at org.usfirst.frc.team2022.robot.Robot.<clinit>(Robot.java:25)
Exception in thread "main" Java Result: 1
BUILD SUCCESSFUL (total time: 0 seconds)
I'm not sure what the HLUsageReporting is and what the exception is saying.
Here's the code for the main class:
package org.usfirst.frc.team2022.robot;
import org.usfirst.frc.team2022.robot.commands.CompressorCommand;
import org.usfirst.frc.team2022.robot.commands.ForkliftCommand;
import org.usfirst.frc.team2022.robot.commands.IntakeCommand;
import org.usfirst.frc.team2022.robot.commands.TankDriveCommand;
//import org.usfirst.frc.team2022.robot.commands.autonomous.Autonomous;
import org.usfirst.frc.team2022.robot.subsystems.ForkliftSubsystem;
import org.usfirst.frc.team2022.robot.subsystems.GyroSubsystem;
import org.usfirst.frc.team2022.robot.subsystems.IntakeSubsystem;
import org.usfirst.frc.team2022.robot.subsystems.TankDriveSubsystem;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.command.Scheduler;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class Robot extends IterativeRobot {
	public static final TankDriveSubsystem tankSubsystem = new TankDriveSubsystem();
	public static final ForkliftSubsystem forkliftSubsystem = new ForkliftSubsystem();
	public static final GyroSubsystem gyroSubsystem = new GyroSubsystem();
	public static OI oi;
	public static final IntakeSubsystem intakeSubsystem = new IntakeSubsystem();
//	CommandGroup autonomousCommand;
	TankDriveCommand tankCommand;
	ForkliftCommand forkliftCommand;
	IntakeCommand intakeCommand;
	CompressorCommand compressorCommand;
	 * This function is run when the robot is first started up and should be
	 * used for any initialization code.
	@Override
	public void robotInit() {
		oi = new OI();
		// instantiate the command used for the autonomous period
//		autonomousCommand = new Autonomous();
		// instantiate the real commands
		tankCommand = new TankDriveCommand();
		forkliftCommand = new ForkliftCommand();
		intakeCommand = new IntakeCommand();
		compressorCommand = new CompressorCommand();
	@Override
	public void disabledPeriodic() {
		Scheduler.getInstance().run();
	@Override
	public void autonomousInit() {
		// schedule the autonomous command
//		if (autonomousCommand != null)
//			autonomousCommand.start();
	 * This function is called periodically during autonomous
	@Override
	public void autonomousPeriodic() {
	@Override
	public void teleopInit() {
//			autonomousCommand.cancel();
		tankCommand.start();
		forkliftCommand.start();
		intakeCommand.start();
		compressorCommand.start();
	 * This function is called when the disabled button is hit. You can use it
	 * to reset subsystems before shutting down.
	@Override
	public void disabledInit() {
	 * This function is called periodically during operator control
	@Override
	public void teleopPeriodic() {
	 * This function is called periodically during test mode
	@Override
	public void testPeriodic() {
The error in the subsystem is at the constructor of the class. Any help is appreciated
