Go to Post Add a little more grease if you aren't sure exactly how much you need. - MrForbes [more]
Unread 20-03-2003, 22:23
tenfour's Avatar
tenfour tenfour is offline
AKA: Chris
#0696 (The Circuit Breakers)
tenfour will become famous soon enough
Send a message via AIM to tenfour
I also thought that we could only use the 2 batts. from this year, but we had 3 matches that were nearly in a row. Since we drain each one completely in 2 minutes, I asked an official about that rule. He (and several others) stated that we could use batteries from the last 2 years. Most teams just do it even though they didn't even ask, but we did the honest thing and still won out.
From what I saw at AZ, just let common sense prevail. Look at the spirit of the rule--Its a shame to not be able to play because the battery is dead.
-Tenfour
-2004 Arizona Regional Finalists (thanks 80 and 498)
-2004 Arizona Regional Sportsmanship Award
-2003 Los Angeles, CA Regional Finalists
-2003 Phoenix, AZ Regional Semifinalists
-2003 Phoenix, AZ Regional 3rd Seed.
-2002 Los Angeles, CA Regional Semi-Finalists
-2001 Los Angeles, CA Regional Semi-Finalists
FIRST Mantra - When Lawyer-ism fails, Gracious Professionalism Prevails.
(Yes, it is "BCR Orange")
Robot/Goal scoring: Official Answer Mike Martus Mike Martus OCCRA 6 21-10-2003 23:51
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
Voltage Range of Analog Inputs Ulibrium Electrical 21 15-02-2002 14:11
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
