Re: Cause of chain ratcheting issues
I can run it through some tests tomorrow but I guess I'm still a little skeptical that this issue would only crop up now, after our other changes. How much deflection in the end of the shaft are you expecting? All the mounts for the motor are still as solid as ever. |
On our 2011 Bot arm, we experienced chain skipping using a long run of properly tensioned dual #25 chains with 16 tooth sprockets. We eliminated the issue by adding a roller that increased chain wrap around the sprockets. We made different diameter rollers to account for chain stretch and sprocket wear throughout the season.
Looking at your pictures.
If you are ratcheting, either the CD is changing or the chain is elastically stretching. CD changing seems more likely to me. You definitely have some drive sprocket wear. Whether or not it is enough to be an issue, hard to say. The wear changes the pressure angle which can increase chain tension for a given torque. Maybe trade the idler sprocket for the drive sprocket? Make provision to take up slack in the chain? The motor support & motor sprocket has a lot of cantilever. Run a piece of flat bar to the frame rails or wheel gear boxes to add a bearing to help support the gear box shaft? |
We have mostly fixed the issue by doing two main things.
After these two changes the ratcheting is gone. However, now when the elevator is under a lot of load I definitely see the motor mount bending upwards, thus changing the c-c distance. It doesn't ratchet anymore because the chain is better aligned with the drive sprocket, but it shows us the next thing to be fixed. Thanks for the help everyone. All of your suggestions have been great. |
It looks like your whole motor mount is sticking out quite a ways from where it attaches to the robot. As others have said, you maybe should have used that piece you cut out to support the motor mount and/or the shaft. Two sprockets need to be as solidly tied together as possible to eliminate that change in c-c distance you are experiencing.
#7
What you say about tieing the sprockets tightly and supporting the motor shaft is all absolutely true, but it's important to know that none of that caused our ratcheting. I know this to be the case because we haven't changed any of that and our ratcheting is completely gone. |
