Go to Post When I saw the title of this thread ("Reverse Robotics"), I thought "what, you get six weeks to take apart a robot or something??" - Katie Reynolds [more]
Unread 07-10-2015, 10:22
Knufire Knufire is offline
Re: pic: FTC Custom Drive Train
Originally Posted by cadandcookies View Post
I don't see a reason why it wouldn't work, but I'd probably go with a couple of the #25 sprockets instead of one of the #35 doubles. I'm pretty sure buying an adapter plus two of the VexPro sprockets is cheaper than getting a single sprockets from AM or Tetrix (although I suppose those have the advantage of just dropping in).
The biggest advantage of the AM sprocket is not having to rely on a set screw to transmit torque from the motor output shaft. AM found the slit + collar clamp method that IceStorm mentioned to be more reliable, which is what that sprocket operates on.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
