Go to Post Even better than any [book] is simply becoming an active member of the Chief Delphi forums. Where do you think I got everything I know? - sanddrag [more]
  #46   Spotlight this post!
Unread 08-10-2015, 21:53
Re: [FRC Blog] 2016 Radio Update
Originally Posted by Sperkowsky View Post
That's quite odd. It looks like everything is there except for the Rio. Did they just decide to give all that stuff to us so they didn't have a lot left over after the control system switch.
That's not something that normally happens right?
It wasn't supposed to happen.
What WAS supposed to happen, back in '09, was: They'd give every team a control system on entry into FRC (or if there was a new system). (cRIO, modules, etc., the whole thing.) After that, as cost saving, they'd only give the stuff that they needed to.
Looks like that's changed.
  #47   Spotlight this post!
Unread 08-10-2015, 22:22
Originally Posted by sraque View Post
We ran one of these at IRI. I am pretty sure we did not need to rewire anything. We just pulled off the DLINK and put this one on.
-Steve
We also ran one at IRI and had to rewire. It was probably just so easy that you forgot.
  #48   Spotlight this post!
Unread 08-10-2015, 22:25
thatnameistaken thatnameistaken is offline
AKA: Joshua Johnston
FRC #2191 (Flux Core)
thatnameistaken is on a distinguished road
Happened in 2012-2013, too, apparently.
http://www.usfirst.org/roboticsprogr...ariation-table
http://www.usfirst.org/roboticsprogr...eran-variation
Going back to 2010-2011, it seems that for all the control system components veterans got, rookies got 2. Odd.
http://www.usfirst.org/uploadedFiles...write%20up.pdf
http://www.usfirst.org/uploadedFiles...ifferences.pdf
Interestingly, it seems giving veterans router models they received previously only started in 2014.
  #49   Spotlight this post!
Unread 09-10-2015, 01:20
Knufire Knufire is offline
-Steve
Can confirm what Joe Ross said, we also ran one at IRI. All you had to do was flip the power wires from the regulated 5V side of the VRM to the 12V side.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
  #50   Spotlight this post!
Unread 09-10-2015, 01:42
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
The blog notes that FRC firmware is not available until kickoff. Does that mean if we buy one now, we won't be able to mess around with it/use it on a practise bot?
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
  #51   Spotlight this post!
Unread 09-10-2015, 01:44
If you take a look at my last post, I don't think it's odd at all.
The original intent was that only new/upgraded components of the control system would be sent to all teams in the KOP, while rookies would get the whole system (because they kind of need it).
2008 and prior: New system, complete, every year, to every team. (Thanks to IFI for their support--and for the ability to run a match within 30 seconds of the last robot turning on.)
2009: New system. Operator box, router for it, D-link for the robot, cRIO, PDP, cRIO modules, and breakouts, to all teams.
2010: Slight modification... Classmates distributed to all teams. I want to say modules and breakouts were also on the distribution list, but more limited.
2011: Same sort of deal as 2010, sans classmate.
2012: See above. A Kinect was also included. But this also saw the Einstein Incident... And there had been some other incidents with wireless.
2013: Everybody gets new router, some modules...
2014: See 2013.
2015: New control system: everybody gets one! (On the robot side at least. OI being what it is, the Classmate is not provided to veterans.)
2016: All we know for sure is: the RoboRIO system is getting a new radio, and thus it'll be in all KOPs sent out. In theory, the rest of the system isn't changing, so there's no need to send everybody everything... but who knows.
  #52   Spotlight this post!
Unread 09-10-2015, 01:59
AndyMark has directions here for installing OpenWRT onto the radio and getting it all set up for home use. I imagine the FRC firmware will be required for connecting to the FMS.
  #53   Spotlight this post!
Unread 09-10-2015, 08:00
sraque's Avatar
sraque sraque is offline
AKA: Steve Raque
FRC #2614 (MARS)
sraque is on a distinguished road
Yes, I was probably distracted with something else when the installation happened.
So, now I agree with the observation that we will see some calls for help as teams wire up to the VRM where last year's sticker says "Radio".
-Steve
  #54   Spotlight this post!
Unread 09-10-2015, 08:28
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The Dlink went from a Rev A to a required Rev B. one of those years. While they look a lot alike, all teams needed a new radio. What comes in the KOP is also dependent on donations.
  #55   Spotlight this post!
Unread 09-10-2015, 08:43
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
We're one of the beta test teams again this year and I believe we'll be testing this radio out. We're going to have to work out an external switching solution so we can keep our vision system working. As a beta team, we'll do our best to keep the community informed about how this shakes out for us.
  #56   Spotlight this post!
Unread 09-10-2015, 10:33
2014: See 2013.
From 2010 onward, literally everything but the cRIO, solenoid breakout, and radio (except when it was new, until 2014), was given to all teams. Even the PDP, which was fairly expensive as I recall. Just based on precedent, I wouldn't be surprised to get another PDP and VRM in this year's KOP; however, as the supplier has also changed, I could really see it going either way.
But back on topic, I'm pretty happy with this radio. The footprint is great, and my team was planning on using a USB camera anyway; no real drawbacks for us. I'll still be interested in know how easy it is to use a switch, though; never know when we'll need another port in the future.
  #57   Spotlight this post!
Unread 09-10-2015, 10:46
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Just bought 2 at the special pricing, which is how the world works. I get quotes all the time for Rockwell Automation parts for my customers and their price is significantly different than my companies price. Its how things are done in industry. Companies sign contracts to get special pricing all the time.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
  #58   Spotlight this post!
Unread 09-10-2015, 20:52
kmodos kmodos is offline
AKA: Alex
FRC #1126 (SparX)
kmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to behold
Its $104.00 for FIRST teams, $135.00 for non FIRST on Andy Mark, just sign in with a team account... I don't see why people wont post the price.
  #59   Spotlight this post!
Unread 09-10-2015, 20:55
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Originally Posted by kmodos View Post
Its $___.00 for FIRST teams, $135.00 for non FIRST on Andy Mark, just sign in with a team account... I don't see why people wont post the price.
Because it is a special price for FIRST Teams only. I don't think the company wants the public to know the Price teams are getting them at.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
  #60   Spotlight this post!
Unread 09-10-2015, 20:57
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
People won't post the price because they respect FIRST and Andymark's decision to keep it hidden. No, it's not hard to access the price, but it was probably hidden for a good reason.
Edit: Ninja'd.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
