Go to Post I need to start sleeping now to make up for build season - Kingofl337 [more]
Unread 09-10-2015, 14:11
Re: Using a different button to e-stop the robot instead of the space key
If you are just tweaking values, you might find it faster and more convenient to use Smart Dashboard variables instead of changing the program each time. Once you have found the value you want, then you can put it in the code.
The robot is going to disable itself anyway when you load new code. Why isn't it possible for you to disable it a few moments earlier?
