Go to Post I would rather Andy Baker be at champs than Will.i.am. - Grim Tuesday [more]
Unread 08-10-2015, 06:28
cjcraigy cjcraigy is offline
FRC #5603 (Rise Of The Warrior Bots)
Rookie Year: 2015
cjcraigy is an unknown quantity at this point
Failed to Deploy, File Permission Error
Over the past week or so, we have had some problems deploying with LabVIEW. At this point we are in a rush with a competition coming up this Saturday. There is no problem building the code, but every time I try to deploy the code it fails And shows;
LabVIEW: File permission error. You do not have the correct permissions for this file.
However running the main vi works fine and we aren't having any connection issues. I've tried reformatting the Rio, using different cables like Ethernet and USB B, running LabVIEW as an administrator, and changing the build file location, but nothing has worked. If it helps any, I've attached a picture of the deployment window after its failed to deploy. Any help would be greatly appreciated. Thanks.
Unread 08-10-2015, 11:13
Re: Failed to Deploy, File Permission Error
I don't recognize the error. Are you trying to "Deploy" the code? If so, don't do that. After you Build it, just "Run As Startup".
Unread 08-10-2015, 11:14
Rookie Year: 2015
The same problem occurs when running as start up as well.
Unread 09-10-2015, 04:18
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
How interesting. I just started seeing this too - but in the 2016 beta. We'll get to the bottom of it, but in the mean time, you can work around it by going to a Linux shell and changing the owner of all files and folders in the /home/lvuser dir to lvuser.
chown -R lvuser:ni /home/lvuser
Unread 09-10-2015, 14:53
Rookie Year: 2015
Changing the permissions results in the same problem. The code will build fine, but can not deploy or "run as startup". Is it possible to build the LabVIEW code to a binary that would be able to be put on the roborio manually?
Unread 09-10-2015, 19:15
Are you sure that you changed ownership as Joe suggested? Can you ls -l the /home/lvuser directory and post the results?
Greg McKaskle
Unread 09-10-2015, 20:37
Rookie Year: 2015
We changed the ownership of the files by ssh into the roborio. The file permission error is gone, but it doesn't deploy all the code. It says it successfully has deployed the code but the robot code light in the driver station doesn't turn green, it stays red
UPDATE:
One of the tech people here at the competition helped us out and we reformatted and updated the firmware on the roborio and now it magically works. Thank you Aaron, if you ever read this.
Unread 09-10-2015, 23:23
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
UPDATE:
Did you remember to restart the robot code once you deployed?
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 10-10-2015, 08:24
Rookie Year: 2015
No we didn't restart the code. That could have been the problem.
