Go to Post There are so many creative and brilliant minds out there that build wonderful inventions and machines---surely we can be equally creative and open minded ... - Tonya Scott 476 [more]
Unread 10-10-2015, 20:51
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Re: MXP Ethernet Switch
Originally Posted by GeeTwo View Post
MXP boards that only interface to sensors, data feeds, computing resources, or decorative lighting are good to go, without certification. Likewise, any MXP board that is entirely passive (has no electronics or computer function, but consist of conductors designed to faithfully replicate signals sent from the 'RIO) is probably good to go.
The proposed switch would not use any of the MXP pins except power. As such, I would not expect it to be subject to RIO regulations (although I've been surprised by rulings before.)
Unread 11-10-2015, 05:20
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
That's not how I read some of the posts above (emphasis mine):
Originally Posted by Richard.Varone View Post
How much interest would there be for a MXP 4 Port Ethernet Switch with additional processing power ( CPU/FPGA )?
How much interest would there be for a MXP 4 Port Ethernet Switch with additional features (please list wanted features)?
How I imagine my team using this product would be RoboRIO Ethernet -> OM5P-AN -> MXP Ethernet switch, our camera(s) and tether would connect to the the MXP Ethernet, our vision processing would take place on the integrated processing power ( CPU/FPGA ) and then talk to the RobotRIO through either/both the SPI/DIO on the MXP and Ethernet.
Originally Posted by TheHolyHades1 View Post
Speaking of which, maybe an arduino MXP board?
Unread 12-10-2015, 02:21
Be aware that the MXP power isn't very good power. It browns out soon after the motors brown out. I would expect to see it go much more often next year.
Unread 12-10-2015, 12:01
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Obviously this is going by 2015 rules. A minor assumption that 2016 rules in area will be similar. An Ethernet switch would considered an active device. Completely legal if you are not controlling motors or servos via the MXP port. If you wanted to use the MXP for motors & servos the board would have to be "approved" even if the outputs pins were a simple pass-thru or even on a different header.
Unread 13-10-2015, 11:43
Depending on the 2016 power rules, it might be worthwhile to include support for either 802.3af-compliant Power Over Ethernet or the less expensive (and less officially standard) simple voltage POE accepted by the OM5P-AN.
Unread 13-10-2015, 12:43
Richard.Varone's Avatar
Richard.Varone Richard.Varone is offline
AKA: Rich Jr.
FRC #0271 (Mechanical Marauders)
Richard.Varone is just really niceRichard.Varone is just really niceRichard.Varone is just really niceRichard.Varone is just really nice
Send a message via MSN to Richard.Varone
After looking for small/cheap POE powered switches, this is exactly where this project might head.
Edit: or maybe not because I found this http://www.amazon.com/BV-TECH-BV-RP1...powered+switch. The question I guess I have for myself now is would I be able to make something smaller/lighter, and I'd like to see if it would be possible to make sometime like this into a dongle that hangs securely off of the OM5P perhaps.
2016 FLR (Excellence in Engineering)
2015 NY (Regional Finalists) & LI (Quality Award)
2014 NY (Regional Finalists, Quality Award) & LI (Regional Finalists, Quality Award)
2011 LI (Regional Finalists, Innovation in Control)
2010 LI (Regional Champion, Engineering Excellence, Coopertition Award) & NY (Regional Finalist)
2009 LI (Innovation in Control) & NY (Creativity Award)
2008 LI (GM Industrial Design) & NY (Innovation in Control)
2007 LI (Delphi "Driving Tomorrow's Technology")
2006 LI (Regional Champion)
2005 LI (Regional Finalist)
2004 SC (Regional Finalist)
2003 LI (GM Industrial Design)
2002 CMP (Division Finalist - Newton)
2001 NY (Imagery)
