Go to Post Blue shirts are ALWAYS watching. And they have spies everywhere. Always be on your best behavior, and be polite to every volunteer at the event. - Andrew Schreiber [more]
Unread 09-10-2015, 10:29
ohdan56's Avatar
ohdan56 ohdan56 is offline
Commander-in-Chief
FRC #4284 (Highlander Robotics Fleet)
ohdan56 is an unknown quantity at this point
Looking for suggestion on a Gearbox replacement/sub
Greetings:
We are looking for feedback/guidance on finding a substitute or replacement for this gearbox:
http://www.andymark.com/product-p/am-2880.htm
We are trying to avoid paying the steep cost (at least in our eyes, LOL) of this part. We are creating some mobile targeting systems for our archery club, and this is our current design solution for the drivetrain that will carry mock deer, bear, and turkey targets around the auxiliary gym.
Any suggestions are welcome, and if someone knows where we can get some of these for cheap, that would be awesome. Cheers,
https://goo.gl/photos/8xZ9ixXRC3x14r5i7
I have not failed. I've just found 10,000 ways that won't work.
- Thomas A. Edison
DB
Unread 09-10-2015, 10:50
Michael Hill's Avatar
Re: Looking for suggestion on a Gearbox replacement/sub
The VersaPlanetary can be configured like that gearbox for about $90
http://www.vexrobotics.com/vexpro/mo...planetary.html
I can't seem to find the load rating guide for it to see if it can handle comparable loads.
Unread 09-10-2015, 11:10
Knufire Knufire is offline
Originally Posted by ohdan56 View Post
Greetings:
What's your target rpm and torque?
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 09-10-2015, 11:14
Monochron's Avatar
Monochron Monochron is online now
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
If you are interested you can use this reference sheet to help you match CIMs to all the different gearboxes taht they can mesh with. It is slightly out of date as newer products have come out. But looking at it tells me that the AndyMark Planetary Gearbox can do roughly what you need, though the price isn't going to be much cheaper. Same with the VersaPlanetary.
Your best bet might be to go with the Vex Clamping Gearbox with Vex plastic bearing block (as shown on the page) and to play with the reduction that you plan on using. It will be a bit more complicated and isn't quite as versatile to mount, but if your main goal is cost reduction then this would be a good fit. I haven't added the cost of those individual items together but I'm estimating that you will still be in the $80 - $90 range approximately.
Unread 11-10-2015, 08:34
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
If you are hoping for something cheaper, consider using Fisher price gearboxes. They are plastic, and good enough to drive kids around.
Unread 11-10-2015, 16:57
Seth Mallory Seth Mallory is offline
FRC #0192 (GRT)
Seth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond repute
AndyMark Toughbox am-2103 has a 14.88:1 ratio and is $75.00.
KF6UZX
Unread 12-10-2015, 08:02
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Why limit yourself to a product solution designed for FRC? I'm assuming you would run this 12V? Why not plug into a wall and not have to deal with batteries? You'll find a lot more motors/gearboxes designed to run full time that can deal with a lot of weight outside of the hobby robotics realm.
We have run into this with a lot of projects we have built for other clubs around the school. The problem with making it based in FRC stuff is that you almost have to have a member present to operate the thing every time it gets used just in case something goes wrong...
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 12-10-2015, 08:46
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
You may want to consider gearing down all or part of the way using pulleys and belts or perhaps by clutching a small wheel to a large wheel; these solutions are less expensive than a gearbox.
Unread 12-10-2015, 11:44
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
To solve the problem of shooting targets...
Build carts to carry your targets and drag them around the parking lot with a car.
Hopefully you will only be using rubber tipped arrows!
Dave
