Go to Post p.s. note that 5-1/2 hours in the car with your daughter on the way to IRI is NOT the same as 10 hours in the van with seven members of Team 116 on the way to IRI. One is a wonderful familial experience, the other is an opportunity to go insane. - dlavery [more]
Unread 12-10-2015, 09:33
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: pic: Inverted CIM 2-Speed Gearbox
I'm not crazy about the tiny idler gear - seems like it'd wear very quickly and as a result become a detriment to efficiency as the season went on. Is that the largest gear you can get for that initial stage?
Originally Posted by KrazyCarl92 View Post
School B:
-Low gear is intended for completing game objectives with a short sprint distance, and again some fine movement tasks.
More and more I find myself learning from the masters in School B for certain games. 2011/12 would more have a School A thought - the field was congested or blocked and objectives needed slow/meticulous movements. 2013/14 required much less precision in control (so long as the intake made up for margin of error) so School B would have dominated.
As a result
- School A needs the best high-traction treads available to maximise performance in the situations the design is made for.
- School B needs tread that WILL slip under enough torque so as to not trip the breakers. Colsons fit that spec nicely, imo.
