Go to Post Like his father, John V-Neun will soon have the advantage of his head resembling a game object. - Eric O [more]
Unread 13-10-2015, 10:57
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Re: pic: 2015/2016 Robot Radio Comparison
Originally Posted by orangemoore View Post
R32 is what will prevent you from doing this. It says you must power the radio from the VRM.
Why would that rule prevent the use of POE injectors? You could easily power the injector from the VRM.
The rule that I see being a problem is R38. It says that regulated circuits < 5A should be wired with 22AWG wire. You can find 22 gauge ethernet cable, but it's not very common.
Unread 13-10-2015, 11:27
AlexanderTheOK AlexanderTheOK is offline
Guy
AlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really nice
Sorry to crash the party, but does anyone have a link to an ethernet switch that is actually reasonably smaller than the original D-Link? Not much of a... net gain (badum tish) in real estate if the new system takes up... you know... MORE space.
Unread 13-10-2015, 11:29
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Different radio. POE wasn't an option on the DLINK. If they decide to allow POE as an option, they will change the rule. Since the radio has been problematic in the past, I expect they will only allow options that have been thoroughly tested.
Unread 13-10-2015, 11:34
R32 would have prevented using a POE injector to power the radio from something other than the VRM, but that was last year's rules, and last year's radio didn't support POE anyway.
I am confident that the 2016 robot rules will address Power Over Ethernet one way or the other, either to make it explicitly legal or to restrict it.
Unread 13-10-2015, 11:52
A typical 5-port switch is slightly smaller than the D-Link wireless router. It takes a little less space on the robot where the D-Link would have been. The new OM5P-AN is thus an extra component, but it can be placed for good radio reception rather than for network wiring convenience if you're using a separate switch.
This assumes that the 2016 rules permit a network switch between the radio and the roboRIO. I can imagine being required to have them connected directly with no intervening devices.
Unread 13-10-2015, 12:26
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Here is another POE injector. It is small, but not a switch, so you gain very little. It is just an easy way to get power into the Ethernet.
Unread 13-10-2015, 12:40
Why would this be an issue? Plug both the roboRIO and the switch directly into the radio.
Unread 13-10-2015, 12:46
Volunteer, WPILib Contributor
no team (Waiting for 2021)
It would save a wire if the roboRIO could go through the switch. Then you would only have to run 1 ethernet cable to the new radio, instead of 1 to the switch, and 1 to the roboRIO.
Team 4488 - Mentor 2013-2016
Unread 13-10-2015, 13:10
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
Here are the POE injectors sold by the company that makes these AP:
http://www.open-mesh.com/products/po...or-for-om.html
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 13-10-2015, 13:12
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
http://www.amazon.com/gp/product/B002HH0W5W
It also runs on 5v.
Unread 13-10-2015, 16:45
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 has a spectacular aura aboutscca229 has a spectacular aura about
Selfishly I am hoping that there "is" a rule requiring plugging the roboRIO into the radio directly, on a designated port (near power, away from power). As an FTAA, I want to be able to say, "Your ethernet cable is not plugged in," and be able to point it out to the team member. Having to search for an unknown device to figure that out makes more difficult when trying to keep to the match schedule. This year I had to say that to teams more than prior years which I think probably had to do with no defense and less secure radios.
Nate
Unread 13-10-2015, 22:30
Roboshant's Avatar
Roboshant Roboshant is offline
Design Lead 17, Scouting Captain 16
AKA: Dikshant Sharma
FRC #0226
Rookie Year: 2015
Roboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to all
Is it waterproof?
Unread 14-10-2015, 20:21
Briansmithtown's Avatar
Briansmithtown Briansmithtown is offline
Pilot shortage, Good thing Im tall
AKA: Brian Sheridan
FRC #0810 (Smithtown Mechanical Bulls)
Briansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond reputeBriansmithtown has a reputation beyond repute
Did it come with a Pear?
2014 Team 810 Recap video https://www.youtube.com/watch?v=DS9K_j1FzF4
Unread 14-10-2015, 23:33
Richard.Varone's Avatar
Richard.Varone Richard.Varone is offline
AKA: Rich Jr.
FRC #0271 (Mechanical Marauders)
Richard.Varone is just really niceRichard.Varone is just really niceRichard.Varone is just really niceRichard.Varone is just really nice
Send a message via MSN to Richard.Varone
My company and I are currently in the process of designing and prototyping such a switch. The goal is to have something with the smallest possible footprint/weight as possible, have 2-4 ports, and possibly also be a POE injector. As it progresses I'll post updates on here, although it won't be move to production until the rules are released and certain requirements/restrictions are laid out.
2016 FLR (Excellence in Engineering)
2015 NY (Regional Finalists) & LI (Quality Award)
2014 NY (Regional Finalists, Quality Award) & LI (Regional Finalists, Quality Award)
2011 LI (Regional Finalists, Innovation in Control)
2010 LI (Regional Champion, Engineering Excellence, Coopertition Award) & NY (Regional Finalist)
2009 LI (Innovation in Control) & NY (Creativity Award)
2008 LI (GM Industrial Design) & NY (Innovation in Control)
2007 LI (Delphi "Driving Tomorrow's Technology")
2006 LI (Regional Champion)
2005 LI (Regional Finalist)
2004 SC (Regional Finalist)
2003 LI (GM Industrial Design)
2002 CMP (Division Finalist - Newton)
2001 NY (Imagery)
Unread 14-10-2015, 23:49
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Originally Posted by Richard.Varone View Post
... I'll post updates on here, although it won't be move to production until the rules are released and certain requirements/restrictions are laid out.
You realize rules will not be posted until kickoff? A direct conversation with First might be in order.
