Go to Post The reason I care about it is that I don't want minorities (whether that's females or other racial minorities) to see the STEM world as only inclusive of majorities or men. - Monochron [more]
Unread 14-10-2015, 20:20
Altainia Altainia is offline
That one geeky guy...
FRC #5098 (Sting-R)
Altainia will become famous soon enoughAltainia will become famous soon enough
Re: I got it to work! USB mice
Originally Posted by GuyM142 View Post
This would be useful in the coming season!
Correct me if I'm wrong, in order to use an optical mouse to track the robot's position it has to be centered around the rotation axis of the robot, otherwise it will sense rotation in place as a change in the robot's position.
It does not have to be centered around the rotational axis of the robot; it only needs to be straight; facing the same direction as the robot as perfect as you can get it. Its 'X' axis needs to be parallel to the robot's 'X' axis. You can put it in the corner of the robot so long as it lines up with the robot's build direction
