Go to Post "The hardest part about building the robot is figuring out what to build..." - Jeff Waegelin [more]
View Poll Results: Do you like the new FIRST logo? Did you even notice? (Choose for both)
I noticed it! 67 41.36%
I did not notice it at first. 67 41.36%
I like it! 29 17.90%
I do not like it. 47 29.01%
I am indifferent to the change. 52 32.10%
Multiple Choice Poll. Voters: 162. You may not vote on this poll
Unread 15-10-2015, 10:15
Billfred's Avatar
Billfred Billfred is offline
Re: FIRST Logo Redesign?
I noticed it in the video (but was warned about it too).
I was around for the change to the present logo eleven years ago, and I remember the uproar at first but it settled out. Considering the relative size of the fish I have to fry globally (Championsplit) and locally (the stalled growth in South Carolina and the paucity of nearby events for us now), I'll update the front of the Garnet Squadron shirt and roll on.
Unread 15-10-2015, 10:18
Joining the 900 Meme Team
FRC #0079
Originally Posted by dag0620 View Post
Technically this is correct. However it is still good practice for any organization to follow it's own branding guidelines. It doesn't really help the brand when they release materials that go against that consistency.
Yup, was just pointing out that it's not a function of "respecting the guidelines" (I'm sure they do) it's a function of they have creative freedom.[1] And that their not following the guidelines in this case doesn't give folks a precedent for ignoring the guidelines.
[1] Note that this applies to USFIRST as an organization and NOT the various Districts and other groups affiliated with it.
Unread 15-10-2015, 11:30
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I did notice that they had intentionally added a dark background and white text, which definitely improves the clarity of the circle.
I suspect that the pieces are "thicker" to reduce the amount of black. Putting the old logo on a black background would probably be too dark. The larger FIRST also has the same lightening effect.
As for the orientation of the triangle and whether the triangle or square is in the front, and the change in font, I'm completely neutral. The red alliance has been in front for a few years, so let blue have a turn.
On the whole, I like #3 at least as well as #2.
Edit: the rotation of the triangle allows the logo to use a larger fraction of the black rectangle, again keeping the logo from being too dark.
Unread 15-10-2015, 11:56
LeapsAndBowns's Avatar
LeapsAndBowns LeapsAndBowns is offline
Don't Forget to be Awesome
AKA: Kori Bowns
FRC #0101 (STRIKER)
LeapsAndBowns will become famous soon enough
I'm a huge fan of the logo change, and more indifferent on the font change. One thing that really bothered me about the current logo is the weird downward slope of it from the triangle to the square. I love that the logo revision captures a logo that looks pretty much the same prior to inspection, but is much more balanced and sits on a straight line.
The new FIRST font is a bit round and cartoony for my taste, but I definitely like the change for it to be centered on the logo as well as a bit larger relative to the logo. I think it will make for easier use of the logo on letterhead, shirts, publication materials, etc. Whenever I design materials with the current logo, it's a bit weird to work around the asymmetry of it.
FRC Team 2903 - NeoBots (Alumna)
Midwest Regional Planning Committee
Illinois FTC Planning Committee
Unread 15-10-2015, 14:53
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
I think a benefit to the new version of the logo is the modifications made to it give it a kind of informal symmetry that is more visually pleasing than that of the current, uneven logo.
Modern graphic design has sort of pushed wordmarks and logotype to the background in favor of a more distinct, sharper, and more universal brand mark. That's why I find it bizarre the relative size of the logotype has increased. Sure the FIRST brand does not have a sizable level of ubiquity, but I don't see how the change to the relative size of the logotype helps that.
Unread 15-10-2015, 15:13
thegnat05's Avatar
thegnat05 thegnat05 is offline
AKA: Natalie Hedberg
FRC #2531 (RoboHawks)
thegnat05 is a glorious beacon of lightthegnat05 is a glorious beacon of lightthegnat05 is a glorious beacon of lightthegnat05 is a glorious beacon of lightthegnat05 is a glorious beacon of light
I personally think that #3 looks a lot more juvenile than the previous 2. It looks cleaner but the change in the font makes it look 'younger.' I don't hate the new look as most of the changes are pretty subtle but I also don't think the change was completely necessary. I'm excited to see what the rest of the marketing materials for this season will look like and if this new logo will make more sense next to everything else.
twitter | blog
FIRST Ladies Staff
Alum of FRC 2531 (12-15)
Unread 15-10-2015, 21:32
sdangelo sdangelo is offline
FTC #10842 (Train of Thought)
sdangelo has a spectacular aura aboutsdangelo has a spectacular aura about
Someone in the video discussion thread just pointed out that the new logo has been removed from the "FIRST Stronghold" graphic. Personally, I take that as an indicator that FIRST intends to roll this out as new branding, and hadn't intended to release it yet.
Unread 16-10-2015, 01:39
cadandcookies's Avatar
cadandcookies cadandcookies is online now
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
I'm not sure I'd agree that it's more juvenile than the first FIRST logo (sorry, I couldn't resist). It's a bit more cartoonish, but the first logo is just... Well, I'm happy it's history. I guess if they're rolling out a new logo, we'll get used to it evemtually.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 16-10-2015, 06:19
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Originally Posted by Jon Stratis View Post
Same here - I've heard that there is new branding coming with an updated logo, that it's been in work at HQ for a while. Unfortunately, I haven't been in a position to see if myself yet . It's probably safe to say that the changes to the logo in the video reflect the new Branding direction.
Just learned the same last night in our RPC meeting. Also that current logos and new logos will be ok to use for the next year.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 16-10-2015, 12:08
kristinweiss's Avatar
kristinweiss kristinweiss is offline
Kristin Weiss
FRC #4468 (Fernbank LINKS)
kristinweiss has a reputation beyond reputekristinweiss has a reputation beyond reputekristinweiss has a reputation beyond reputekristinweiss has a reputation beyond reputekristinweiss has a reputation beyond reputekristinweiss has a reputation beyond reputekristinweiss has a reputation beyond reputekristinweiss has a reputation beyond reputekristinweiss has a reputation beyond reputekristinweiss has a reputation beyond reputekristinweiss has a reputation beyond repute
From what I've heard, FIRST is doing a lot of rebranding and is making this the new official logo and is changing the color for FTC and possibly some of the other levels.
Kristin Weiss
4468 Alumni and Mentor
Student 2013: Peachtree RI // Peachtree DLF
Mentor 2015: Peachtree Finalist // Peachtree REI // 2016: PCH Columbus Winner // PCH Kennesaw DEI // PCH DCEI
Unread 16-10-2015, 12:15
maths222 maths222 is offline
FTC FTA
AKA: Jacob Burroughs
maths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to behold
Why are they taking away our yellow?
--Jacob
Illinois FTC FTA
Unread 18-10-2015, 22:07
Angeliukm's Avatar
Angeliukm Angeliukm is offline
Design, scouting, & branding mentor
AKA: Katelyn
FRC #0020 (The Rocketeers)
Angeliukm has a spectacular aura aboutAngeliukm has a spectacular aura aboutAngeliukm has a spectacular aura about
Time to go update the team branding materials again...
Logos change, and we'll get used to it. I do like that the angle of the triangle and square match up where they meet now, forming one continuous line. The overall increased symmetry in the logo is nice, since getting the old slightly asymmetrical logo to fit in designs has always been a bit of a hassle. While I like the previous design a lot, the new one will be easier to work with. I'm guessing that's what FIRST was aiming for with the redesign.
The biggest thing I'm really not a fan of the new font. It just doesn't look as professional and clean, and distracts from the rest of the logo. With the sizing change, the leftmost stroke of the "F" almost lines up with the triangle's edge - but not quite - which is going to bother me for a while. Also, I wish they would have fixed the kerning of the "S" while they were at it. Then again, these are just my personal preferences as someone who has spent far too much time working on FIRST-related graphic design.
Unread 18-10-2015, 22:10
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Originally Posted by Rachel Lim View Post
I did notice the change in the square overlapping the triangle instead of the other way around.
This might be the change that's bothering me most.
Unread 18-10-2015, 22:42
Jacob Bendicksen's Avatar
Jacob Bendicksen Jacob Bendicksen is offline
Figuring out what's next
Jacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond repute
Even with this, I'm a little disappointed that the new branding didn't roll out over the summer. We've already ordered (and received) our shirts and sweatshirts for this year, so it'll take another year for us to use the 'correct' logo.
jacobbendicksen.com | @jacobbendicksen
Yale University Class of 2020
Team 1540 | 2012-2016
7 Chairman's Awards, 6 other awards, 2015 Dean's List Finalist, 1 event win, 2 finalist finishes. Thanks for an amazing ride.
Unread 18-10-2015, 22:45
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
I'm probably echoing earlier sentiments, and I understand that change is a process; but the third logo looks childish compared with the second one, which looks very bold and professional.
2012 - 2015 : 624 CRyptonite
Team Website
