Go to Post Iteration is something everyone can do. - [more]
Unread 17-10-2015, 14:07
SerpentEagle's Avatar
SerpentEagle SerpentEagle is offline
AKA: Shashank Rajesh
FRC #3641 (The Flying Toasters)
Team Role: CAD
Rookie Year: 2015
SerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to behold
Re: Dog Shifting Gearbox Feedback
Originally Posted by Joe G. View Post
It looks to me as though this problem can be fully solved by rotating the CIM slightly. Even if there's an alternate means of getting at this screw, it's better to address it the "correct" way at this stage.
A couple extra minutes of CAD work is a couple extra minutes you have to work. A couple extra minutes of between-match maintenance is a couple extra minutes you have to work, a couple extra headaches, and potentially a couple crucial matches where your robot is dead on the field.
Good point, I actually did solve this problem by rotating both CIMs inwards by 10 degrees, though it did take another 3 mins redoing the pockets.
Unread 17-10-2015, 16:03
AdamHeard's Avatar
Lead Mentor
Originally Posted by KrazyCarl92 View Post
Honestly, I often see the tradeoff between #25 and #35 chain in a drive train application severely underplayed here on ChiefDelphi. The truth is there are pros and cons to each, and teams should evaluate which size chain they use.
It is not uncommon for a robot to weigh 150 lbs with a battery and bumpers and then have a CoF on their wheels of 1.2. That means you'd have 180 lbs of tractive force or 90 lbs per side of your drive train. If your sprockets have a pitch diameter of approximately 2 inches and you have 4 inch wheels, that's up to 180 lbs of force going through your chain! Nothing close to this will usually happen on a WCD in most cases because the center wheels will likely be direct driven and carry the majority of the tractive force, but this depends on your CoG.
#25 Chain Pros:
-Lighter Weight (~1.0 lbs/foot)
-Takes up less width
#25 Chain Cons:
-May require tensioning (higher part count)
-Co-planar sprockets are more critical (more precise machining)
-May come close to pushing limits (have to do the math)
#35 Chain Pros:
-Can probably get away without tensioning (lower part count)
-Sprockets less sensitive to axial position (less precise machining)
-High safety factor on chain working load
#35 Chain Cons:
-Heavier (~2.5 lbs/foot)
-Takes up more width
For the top teams, the extra 10-15 lbs you'd be saving by going with #25 chain is well worth it. These teams have no problem getting their sprockets co-planar sprockets and have experience doing the math to see if they're doing anything risky. On a WCD, the direct drive of the dropped center wheels off of the gearbox reduced the amount of the force that will be in the chain. For teams that may benefit from a lower part count, might have difficulty making co-planar sprockets, and deem the peace of mind of something that will "just work" to be more valuable than the weight savings, an argument can be made for using #35 chain.
I'd estimate that for about 75% of FRC teams, if they were to use chain they should at the very least think about these tradeoffs. What works best for the best teams in the world may work best for them as a direct result of their goals and resources, while it may not necessarily be the blanket best solution for all teams across FRC.
These chain weights are off. #25 chain is about .1 lbs/ft and #35 is around 2-3x that.
Unread 17-10-2015, 18:40
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #0020 (The Rocketeers)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
You're right, thank you Adam. I meant 1.0 lbs/10 feet for #25 chain and 2.5 lbs/10 feet for #35 chain. That makes the difference in weight on the whole robot only about ~1.5 lbs.
Originally Posted by SerpentEagle View Post
When calculating, you must account for the largest diameter component acting on the gearbox, right? i.e. If you have a 6 wheel setup with 4in wheels and 2in diam sprockets, you only account torque loss with the wheels because they have the largest diameter, or am I missing something here?
I'm not sure what you mean here. I didn't talk about "torque loss" at all in my previous post.
If you want to know the max amount of tension possible in your chain is, a quick and dirty way of getting there is:
Take your robot's weight. Multiply that by your wheel's CoF on the playing surface. Now multiply that by the ratio of your wheel diameter to your sprocket pitch diameter, making sure you use the same units. Divide by 2 because each half of a tank drive is assumed to support half the weight of the robot.
Tension_max = Mass * CoF * D_wheel / D_sprocket / 2
This will tell you the necessary tension in your chain to make one of your wheels slip when it is supporting half of your robot's weight. Now in reality, one wheel will not be supporting half of the weight, it will be distributed among multiple wheels on that side of the robot. And the wheel that most commonly supports the majority of the weight of the robot will be the one directly driven off of a gearbox on a WCD (your dropped center wheel). And since you have a dropped center direct-drive wheel in a WCD, it is not necessarily a crippling issue to toss a chain.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 17-10-2015, 19:49
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Scott Kozutsky will become famous soon enough
I know 1114 uses #35 chain on their tankdrives because they run exact center to center and avoid tensioners. They also try to match their drive wheel diameters to the pitch diameters of the wheels (not really possible on most WCDs). #35 is definitely overkill but overkill is nice to have in a drivetrain. (low maintenance too)
Tangentially, I want some enterprising company to makes usable sprockets for bike chain. Bike chain is stronger and lighter per length than #35, more resistant to misalignment, more readily available and has readily available and awesome chain tools for relatively cheap. Also comes in cool colours.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
Unread 17-10-2015, 23:08
BenGuy's Avatar
BenGuy BenGuy is offline
Co-Driver - 3641 - Flying Toasters
AKA: Ben
Team Role: Operator
BenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of light
Shashank, if we were to make this in the near future, you'd have to simplify the part, there is no way that this can be made on the bridge port, this would have to laser cut and we usually can't cash in on our sponsorship benefits from Superb until well into build season. Even if it will weigh a half a pound more, that's fine, just make an iteration that is feasible to make parts for on the mill if we are going to need it in the near future.
Ben Wolak
The Flying Toasters Website
Team YouTube
Team Twitter
The real problem with computers is that they do what you tell them to do, not what you want them to do.
Unread 18-10-2015, 00:26
Knufire Knufire is offline
I've been looking into better optimizing parts for machine time over this off-season, especially gearbox plates like these which sucked up a ton of waterjet time for us. One thing I'm exploring is using unpocketed 1/8" plates with additional standoffs, after looking at 2826's robot.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 18-10-2015, 13:33
FRC #1836 (MilkenKnights)
That is totally viable, especially on anything that doesn't exit the frame perimeter.
Unread 18-10-2015, 16:13
Team Role: CAD
Rookie Year: 2015
Sorry, I think I got mixed up on who I was replying to haha. But my question was do you have to account for the size of the sprocket when calculating torque loss? I would guess not as the majority of force is applied on the wheel.
Unread 18-10-2015, 16:17
Team Role: CAD
Rookie Year: 2015
Ben, did you forget that we are getting a CNC mill?
PCNC 1100 Education Package: http://www.tormach.com/store/index.php?app=ecom&ns=catshow&ref=PCNC1100_Package s_Ed1
I'm pretty sure that 1114 has used 1/8 inch plates with bends for many of their drive boxes. I wouldn't think it would be a problem.
Unread 18-10-2015, 16:25
Yeah, I found plenty of examples of bent 1/8" gearbox plates but we don't have access to a decent brake.
Unread 18-10-2015, 16:33
Team Role: CAD
Rookie Year: 2015
If you do some searching on harbor freight, you will find many hand brakes for under $80. They would do just fine for simple bends.
It looks like there's a shop right in your city: 1800 Fort Harrison Rd # 21, Terre Haute, IN 47804
EDIT: My bad, it seems that the only brakes online at harbor freight that can bend 1/8" aluminum cost over $200. I'm sure that if you guys use a strong grade of aluminum with frequent standoffs, you should be just fine.
Unread 18-10-2015, 17:20
There is a strength gain just by using 6061 alloy over the 5052 alloy, which is usually used in sheet metal fabrication for its ease of bending.
Unread 18-10-2015, 20:25
Team Role: CAD
Rookie Year: 2015
^This
On second thought, It would probably be much better to just use 6061-T6 plates in place of bent 5052 as it provides greater rigidity in comparison as Michael stated. Just don't use any pockets.
Unread 18-10-2015, 20:30
AdamHeard's Avatar
Lead Mentor
To elaborate more, there is a strength advantage but not a stiffness advantage. So there are many applications where people might think their plate is too "weak" where changing alloy won't help at all, as what they really want is stiffness.
Unread 18-10-2015, 20:35
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
We have run unlightened 090 5052-H32 gearbox plates without any bends for a couple of years. The only issue we have had is that the VEX hex bearings (or at least the old ones) don't press well in thin plates due to the excessive undercut. We fixed that this year by using thunderhex. That said, our opinion is that the gearboxes are louder when made of thin plate. We are looking to go to .1875 plates with lightening this year due to getting some additional machining resources, we will see how those end up.
