Go to Post It'll take some engineering, but you would have yourself something revoloutionary. Keep innovating! - Greg Perkins [more]
Unread 18-10-2015, 21:04
kyle_hamblett's Avatar
kyle_hamblett kyle_hamblett is offline
Hamby
FRC #1073 (The Force Team)
kyle_hamblett will become famous soon enoughkyle_hamblett will become famous soon enough
How to build good bumpers
I figured in light of Frank recently confirming the return of bumpers, I would see what other teams have done in the past that has worked, and maybe what has not worked regarding good bumpers. For 2014, 1073 used hinges , some c-channel, and a few pins that we could swap out fairly quickly. The only problem was that the hinges weren't all that great, and IIRC, they were constantly loose.
Unread 18-10-2015, 21:10
SerpentEagle's Avatar
SerpentEagle SerpentEagle is offline
AKA: Shashank Rajesh
FRC #3641 (The Flying Toasters)
Team Role: CAD
Rookie Year: 2015
SerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to behold
Re: How to build good bumpers
I know that either 1114 or 254 (I cant remember) uses a special low friction material to slide by opponents during pin-holds.
Unread 18-10-2015, 21:14
I believe 254 uses sailcloth or something similar.
The biggest thing with bumpers is to get the fabric nice and tight. What some teams will do is to staple (or otherwise secure) one side of the fabric, then have several people stretch it over the noodles and hold it while someone staples the other side down.
Unread 18-10-2015, 21:20
Chris is me's Avatar
AKA: Pinecone
Tape your noodles in place before you wrap the bumper. This helps a lot in the assembly process and especially helps prevent sagging noodles.
Staple one side, then stretch the fabric as tight as you can before stapling the other side. Any amount of sag in the bumper is bad.
Remember that your bumpers can (by 2014 and previous rules) weigh up to 20 pounds, and there's no reason you can't make your structure that you use to mount the bumpers as beefy as you would like.
Unread 18-10-2015, 21:35
TheHolyHades1 TheHolyHades1 is offline
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
For reference, our standard set of plywood bumpers mounted with wood tee nuts weigh somewhere around 12 lbs, so there is a lot of room to grow.
Unread 18-10-2015, 22:07
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
The Lunatecs have recently made reversible bumpers out of thick fabric and velcro. Basically the red and blue fabric is sewn together on one side and then again in the middle. The free ends are then stapled to the backboard. Volia, you add velcro and you have a single set of bumpers that can be used for both (or all 3) alliances.
2015 MAR District Champions
Unread 19-10-2015, 00:43
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Another trick used to get the bumpers tight is to compress them before stapling. Some teams report using a custom device they made, but we just used our three large (10"?) c-clamps and a table top, and do one edge at a time.
Securing bumpers them with angle brackets works well, as long as you have an inch or more of bumper above the top of your frame perimeter. Mount two bolts to each side of the chassis facing up (should be easy with the KoP chassis; just use the holes already there), drop the bumpers over the robot into place, and secure with a second nut on each bolt. (Wing nuts or power nut driver recommended). Rivet nuts mounted in the frame and (captive?) bolts passing through the bumper's brackets could probably also be used for this, but we haven't tried it.
Unread 19-10-2015, 04:42
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
This^
It's more work during the build, but it is so worth it at competitions.
You will need a heavy duty sewing machine to work with the sailcloth.
Unread 19-10-2015, 07:45
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Totally agree with reversible bumpers. Why have a quick change bumper when you can just flip the color around even faster.
https://www.youtube.com/watch?v=XYTiRxLw7oA
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 19-10-2015, 09:07
AKA: Pinecone
By the 2014 rules (and specifically the Q&A), pre-compressing your bumper noodles as you assemble them isn't legal. I'll find the actual rule after work, but I remember this being shown / proposed in a CD thread in 2014 and a Q&A ruling came in declaring it illegal. Sorry for the vagueness.
Unread 19-10-2015, 09:48
natejo99's Avatar
natejo99 natejo99 is offline
Captain/Human Player
AKA: Nate Johansen
FRC #0074 (Team C.H.A.O.S.)
natejo99 is on a distinguished road
Team 74 did the same thing in 2014. It was pretty convienient at competitions.
2013-Present - Student, FRC 74
2014 FRC Champions - 254, 469, 2848, 74
2014 FRC MSC Finalists - 1718, 67, 74
2016 Traverse City District Winners - 3688, 74, 6128
2016 Tesla Quarterfinalists - 74, 2054, 4468, 3238
Thanks to our 2016 Alliance Partners:
4580, 71, 2405, 3572, 3688, 6128, 5505, 2054, 4468, 3238
Unread 19-10-2015, 09:53
jwfoss jwfoss is online now
Chasing Elegant Simplicity
AKA: Justin Foss
In my mind the reversible bumpers and bumper covers teams have produced in the past never looks as "polished" as separate well made bumper sets. The key to good looking bumpers? Pick quality materials (plywood, noodles, and fabric) and take your time.
Unread 19-10-2015, 10:02
philso philso is offline
FRC #2587
Yes. Plywood. Get the good, sanded both sides stuff, not the sheathing grade that is rough. It's only a few dollars more.
In 2014, someone decided hardwood planks (oak or maple, I think) would be suitable. They ended up splitting along the grain in several places.
Unread 19-10-2015, 10:04
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
From 2014:
Q302
Q.R21 C states that teams should use a pair of 2.5" pool noodles. Does that requirement refer to the pool noodle's size when on the robot, the pool noodles size when purchased, or both? Is compressing pool noodles legal?
A.1) Both. 2) No.
Please note that while previous answers like this may provide guidance on the general thinking towards a rule area, unless/until it's asked for this season, there is no official ruling that applies for this year. Which means you may or may not be flagged for it by an inspector if it's not crystal clear in the rules/q&a for this year.
2016: Lake Superior WFFA
Unread 19-10-2015, 10:10
Sure, separate sets may look a little better than reversible bumpers (and everything looks better than bumper covers!), but honestly, the convenience factor more than makes up for any slight visual difference between them, assuming they are both well made.
A few years back we had a huge issue with our state championship and teams bumpers. With only 30 teams at the event, you were queueing after only being in your pit for about 10 minutes. Teams with separate bumper sets had a lot of trouble making that turn around time... And let's face it, you want to spend that time on robot improvements, not changing your bumpers!. Good reversible bumpers look good and can be changed by one person in under a minute while standing in the queueing line. You just can't beat that!
