Go to Post There are two types of team members and mentors: Those who want to be FIRST, and those who want to be first. - Tetraman [more]
Unread 19-10-2015, 12:29
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: RoboRIO MXP Breakout
Originally Posted by Jaci View Post
I can see FIRST's concern, but if a schematic for something as simple as a Trim were to be sent in and put through approval (i.e. a direct passthrough, but will be blocked when an external signal is active, therefore no auxiliary signal generated for the PWM), I would hope it would be at least possible
That is not exactly simple. You are intercepting the PWM signal and sending out a new one with the trim added. I don't see this ever getting approved. (disclaimer: I have nothing to do with the approval process.)
