Go to Post We try to do cool stuff (note: I didn't say it always works). - marshall [more]
  #31   Spotlight this post!
Unread 20-10-2015, 12:26
hank2247's Avatar
hank2247 hank2247 is offline
FRC #4388 (Ridgebotics)
hank2247 will become famous soon enough
Re: spud gun/T-shirt gun valve
the sprinkler solenoids are rated for 150 psi
  #32   Spotlight this post!
Unread 20-10-2015, 13:18
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
150PSI gas?
Sprinkler valves are generally only rated for liquids.
P.S. It's the valve portion, not the solenoid that's rated for pressure
___________________
- Tennyson, Ulysses
  #33   Spotlight this post!
Unread 20-10-2015, 14:28
hank2247's Avatar
Originally Posted by Daniel_LaFleur View Post
150PSI gas?
Sorry I meant the valve not the solenoid.
I'm not sure if it was rated for gas and liquid but i know it was 150PSI.
Either way it should have the same chance of failing regardless of Air/Liquid. It's just that if it fails with air the results will be much worse.
  #34   Spotlight this post!
Unread 20-10-2015, 14:44
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Compressed air has more energy than compressed liquid. You want to use a valve that's specifically rated for compressed air.
  #35   Spotlight this post!
Unread 20-10-2015, 16:10
hank2247's Avatar
Compressed gas does have more energy than compressed liquid, but the force exerted on the valve is the same. Pressure is pressure, air just compresses significantly more than liquid so its potential energy under pressure is much greater.
  #36   Spotlight this post!
Unread 22-10-2015, 08:55
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
precisely. That's the part of this discussion that convinced me (and my teammates) that continuing to use a sprinkler valve was a Bad Idea™.
