Go to Post EVERYONE on the team is offered the same opportunities to be a team player, it is up to each person to step up and play the game. - MariaCastro [more]
Unread 20-10-2015, 15:47
estuckey17 estuckey17 is offline
FTC #0772
estuckey17 is an unknown quantity at this point
[FTC]: Servo Legality FTC
We are looking at using new servos this year that are not made by Tetrix. I looked into the game manuals and the rule for whether or not we can use other servos is not specified. It says that we are only allowed to use the servo controllers provided by Tetrix but does the same apply for the actual servos? Any information on this would be helpful.
Unread 20-10-2015, 15:51
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
Re: [FTC]: Servo Legality FTC
For an official answer, ask it in the Official Q & A Section of the FTCfourms.
http://ftcforum.usfirst.org/forum.php
An Un-official Answer: Yes, you can use other servos than the ones provided by tetrix, but they need to fit within the specs of the servo controller.
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
Unread 21-10-2015, 06:12
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
DavisDad will become famous soon enoughDavisDad will become famous soon enough
You can also use:
  1. Legaacy Tetrix Controller
  2. Legaacy Matrix Controller
  3. MRI Core Device Interface Module
RE04: "Any compatible servo may be used"
MRI Servo Controller info: "Total servo power limit 6 volts DC. 5A max"
Using the MRI controller, it looks like you can use any servo that has <= 5 Amp power draw @ 6 VDC
I'd ID the servo you'd like to use and then post a question at the FTC rules forum about its legality as the game manual isn't very explicit about the limits. http://ftcforum.usfirst.org/showthre...ll=1#post19054
