Go to Post I think Baker has lost it. - Andy Baker [more]
Unread 21-10-2015, 21:24
kdems kdems is offline
kdems
FRC #5183 (devilbots)
kdems is an unknown quantity at this point
Compressor on/off button programming
I`m looking to program one of the buttons on our joystick for our robot so the compressor can be turned on and off during operation. we plan on driving it around for a pep assembly and i don`t want the battery's to get low, plus we wont be using very much of our pneumatics system during it, so a button to turn off the compressor would be very ideal. any help with this would be greatly appreciated
Unread 21-10-2015, 22:32
Re: Compressor on/off button programming
A properly-connected pneumatics system will run the compressor only when the pressure drops below 90 PSI, and will turn it off once it reaches 115 PSI. Unless you have a significant air leak, your compressor will stay off when you're not using air.
If you still want to disable the compressor completely under program control, you can do that. There are a pair of functions in the Compressor palette named Start and Stop. Just invoke the Stop function when the joystick button is pressed (and invoke the Start function when a different button is pressed so you can go back to normal operation).
Unread 22-10-2015, 07:10
kdems
oh thanks im noob at programming
Unread 22-10-2015, 08:56
mastachyra's Avatar
mastachyra mastachyra is offline
FRC #2781 (RoboPride)
mastachyra is just really nicemastachyra is just really nicemastachyra is just really nicemastachyra is just really nice
Could you take the breaker out of the compressor circuit for the time being?
Someone can advise if this would be unsafe. I don't see why it would be, but I am not all-knowing.
2014: EtaBot - MWR/30th place/no PO
2015: ThetaBot - MWR/30th place/no PO, R2OC/Winners, IndyRAGE 5th Alliance, WMRI QF
2016: IotaBot - MWR/16th place/QF, R2OC/7th Alliance Captain/QF, Boiler Bot Battle/6th place/Finalist
Unread 22-10-2015, 09:08
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
With the new control system, there is no (accessible) breaker for the compressor; power comes directly from the PCM. You can unplug the compressor from the PCM, but then you will have to deal with a dangling wire and remembering how to plug it in when you want to use it. It's probably easier to just disable it with code, and then you can re-enable it remotely without needing to power off the robot, find the wire, etc.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 26-10-2015, 09:35
F35freak F35freak is offline
AKA: Morgan
FRC #2059 (Hitchhickers)
F35freak is an unknown quantity at this point
I have some code for a compressor on/off buttons if you still need it.
