Go to Post Off time, at a regional? What is that? - DonRotolo [more]
Unread 22-10-2015, 20:27
Team5709 Team5709 is offline
FRC #5709
Team5709 is an unknown quantity at this point
Limit Switches
hello i ma a lead programmer from team 5709 the rudyard nerfherders and i was wondering how do i program limit switches to stop a motor from rotating a certain way when it is closed?
so if the elevator hits a limit switch on the bottom it will only be able to allowed to go up and not down anymore.
Unread 22-10-2015, 21:14
Certified Nerd's Avatar
Certified Nerd Certified Nerd is offline
The Only Certified Nerd! GOT IT?!
AKA: Danny
FRC #3840 (TNT)
Certified Nerd is an unknown quantity at this point
Re: Limit Switches
I can't answer your question, but you will need to share the programming language you are using as well as weather you are using NC or NO for the limit switch. Once this info is provided someone on here should be able to help you.
Unread 22-10-2015, 21:51
FRC #5709
Re: Limit Switches
i ma using java and i would like to know how to do it for them both
Unread 22-10-2015, 23:50
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Re: Limit Switches
Hi,
The simple way to do this would be with an if statement:
double speed = getJoystickAxis();
if(limitswitch.get() && speed<0)
    speed=0;
motor.set(speed);
That makes your motor output 0 instead of a negative value when your switch is pressed, but still allows it to have a positive value
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 23-10-2015, 00:32
ShortCircuit908's Avatar
ShortCircuit908 ShortCircuit908 is offline
King of Hacky Fixes
AKA: Caleb Milligan
FRC #4450 (Olympia Robotics Federation)
ShortCircuit908 is an unknown quantity at this point
Re: Limit Switches
This topic has been explained more in-depth in a previous post: http://www.chiefdelphi.com/forums/sh...d.php?t=134642
You can probably find the best answer there.
