Go to Post It always surprises me how many teams wait until their robot is being inspected to learn how files should be used. - Richard Wallace [more]
Unread 24-10-2015, 18:51
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Trouble-shooting Low Traction
Originally Posted by IKE View Post
You could have them all hooked together and at a higher weight than robot can pull (say 300 lbs), then record initial weight and weight at stall and the difference would be the pull weight.
Originally Posted by alecmuller View Post
I like that - like some of the teams used with their hooks to lift totes & hold them a fixed distance apart this past year. It would also provide a "stair-stepped" resistance instead of suddenly hitting the full load all at once. Unfortunately I'd need to get lighter weights (because my ~20lb weights are very low resolution).
Not quite what I think Ike had in mind - something more like:
  • Place a single load on the back end of the cord that is greater than the maximum pull your robot can lift, but less than the top limit of your scale.
  • Put the scale under the load, in the configuration ready to be lifted.
  • Record the reading on the scale.
  • With someone watching the scale, turn the robot on, and gradually increase the pull until a wheel slips.
  • Record the lowest weight on the scale just before spin-out.
  • Subtract the pre-spin-out weight from the full weight to get tension in the cord at the point of maximum traction.
  • Add/multiply whatever fudge factor is needed to account for the friction in the pulleys to get the maximum traction force.
