#16
Re: Trouble-shooting Low Traction
Thank you for the ideas. That 3/4" plywood is essentially the whole chassis (all 4 drive pods are screwed to it), so it's pretty stiff relative to the weight of the robot. I don't have a whole lot of margin on the pneumatics (which deploy the traction wheels), so I don't think I'd be able to get away with reducing the pressure very much. I believe all 4 wheels are carrying pretty close to the same weight (due to symmetry), but I don't have 4 identical scales to verify that with.
Coupling the front & rear wheels tank-style sounds like a great solution for most 4 & 6 wheel robots; unfortunately it defeats (or complicates the heck out of) the mecanum part of the Octocanum in my case. At the moment I'm still trying to debug the power-ramping code (to avoid going straight to full power and slipping the wheels). My first attempt (based on the arduino clock time) didn't move at all. I need to find an easy-to-use clock function in Arduino . . . |
#17
How did you measure the tension to lift through the pulleys with a bathroom scale?
#18
You could have them all hooked together and at a higher weight than robot can pull (say 300 lbs), then record initial weight and weight at stall and the difference would be the pull weight.
#19
I realize I neglected to point directly to my calculations. This Google Sheet (specifically the "Architecture" tab) has my traction calculations (lines 220 to 410). |
#20
Those interested in this type of testing may be interested in American Weigh Scales model PK-110. This small digital hanging-style scale can be set to record peak force pulling on the hook. It operates horizontally as well as vertically so it is easy to use to measure robot pulling power, as well as weighing parts, testing robotic arm lifting power, checking crimp pull-out strength and many other force measurements. The scale reports weights below 44 pounds to 0.02 pounds, and weights above 44 pounds to 0.1 pounds. I tested two scales against highly accurate lab scales and found that one was right on while the second averaged 0.1 pound too low. The scales cost about $45 and have held up well over a year. The only downside is their max capacity is 110 pounds, so we use two in tandem to measure larger weights/forces.
#22
In addition to our digital flat scale, we have four old-school fish-weighing scales from the sporting goods store. We have four so that we can hang a robot by the axles of the four corner wheels, and figure out where the CoG is (we did Mecanum in 2014, and H/slide in 2015). Not as elegant as the digital peak-recording variety, but they've met our needs.
