Go to Post We have tried doing the cha-cha slide on the airplane, but that went away very quickly - it seems that the pilots don't like all the movement in the plane. - Carol [more]
Unread 27-10-2015, 08:12
Coach Seb's Avatar
Coach Seb Coach Seb is offline
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
Tetrix motor bench test device
Anyone successfully powered a tetrix motor without the controller setup ?
I just want to setup a bench prototype station where we could turn the motor with a single switch to do some design testing on bal pickersmor other ideas...
Any ideas, pictures and input would be appreciated.
Coach Seb
Unread 27-10-2015, 08:16
wgardner's Avatar
wgardner wgardner is offline
wgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to beholdwgardner is a splendid one to behold
Re: Tetrix motor bench test device
Coach Seb
You can plug motors directly into the battery to get them to run. Swap the leads and they run the other way. Put a switch inline if you want to quickly turn it on and off.
I've also used this supply for occasional benchtop tests where I wanted to compare motors at pseudo-identical power.
CHEER4FTC website and facebook online FTC resources.
Providing support for FTC Teams in the Charlottesville, VA area and beyond.
Unread 27-10-2015, 09:42
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
I tested Tetrix motors a few years ago when FRC was using them in mini-bots.
Not sure if those results are still useful now, because the motor might have changed.
Richard Wallace
since 2003
Unread 27-10-2015, 10:21
wgardner's Avatar
Yes, there's a V2 of the Tetrix motor out now that is stronger in bench tests. Many FTC folks are using AndyMark Neverest motors as they don't smoke as quickly during a stall as the Tetrix ones do, and they come with encoders built in.
Unread 27-10-2015, 12:37
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
DavisDad will become famous soon enoughDavisDad will become famous soon enough
Anyone successfully powered a tetrix motor without the controller setup... Any ideas, pictures and input would be appreciated.
Coach Seb
We set up a rig by using old kill switch with Power Pole connectors.
wgardner- haven't forgotten Tetrix and AM motor testing. Working on a rig to test with bots from wheel. Could use to troubleshoot drive issues.
