Go to Post While science and technology can solve difficult problems, it is people and interaction that make it all work. - DonRotolo [more]
Unread 27-10-2015, 18:52
itsjustjon's Avatar
itsjustjon itsjustjon is offline
#HoldStrong
AKA: Jon
FRC #3309 (Friarbots)
Team Role: Marketing
Rookie Year: 2015
itsjustjon has much to be proud ofitsjustjon has much to be proud ofitsjustjon has much to be proud ofitsjustjon has much to be proud ofitsjustjon has much to be proud ofitsjustjon has much to be proud ofitsjustjon has much to be proud ofitsjustjon has much to be proud ofitsjustjon has much to be proud ofitsjustjon has much to be proud of
Best Adhesive for Metal-on-Nitrile
What's the best type of adhesive to use for gluing nitrile rubber tread to aluminum wheels?
2016: Beach Blitz Lead Queuer, Newton Quarter-finalists, Orange County Regional Winners, Los Angeles Regional Dean's List Finalist, Los Angeles Regional Chairman's Award Winner
2015: Curie Quarter-finalists, AZ West Regional Winners, Las Vegas Regional Finalists
Unread 27-10-2015, 18:53
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Best Adhesive for Metal-on-Nitrile
I'm assuming rivets and zip ties don't count as adhesives.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 27-10-2015, 19:01
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
You will want to rivet them so you can remove worn out tread. If you got any questions just email me.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 27-10-2015, 20:16
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
I was going to say.
Your best "adhesive" here is almost definitely rivets, unless you want to replace your entire wheels when your tread wears out.
If you really, really want an adhesive, you might try VHB. Properly cured that stuff isn't ever coming off.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 27-10-2015, 20:55
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
If you're stuck on adhesives (pun at least semi-intended), the obvious choices are CA (Cyano-acrylate), rubber cement, Gorilla Glue, Eastman 910, and Shoe Goo. I have not attempted such a bond, but I suspect that CA is too brittle for this application and would provide poor grip on the rubber side. I also suspect that Shoe Goo (which is designed to keep soles from peeling away from shoes) is most likely to satisfy, followed by Gorilla Glue and Eastman 910. Rubber cement isn't really that strong, but it always comes to mind in situations with flexible/torsional stresses. If your aluminum has a shiny finish (as most 6061, or 6063, and 7075 items do), I would suggest adding some texture to the surface with an etching acid as though you were preparing to paint it, so the glue can get a better grip. If you have a cast wheel, you may be OK with the finish.
Repeat: I have not attempted such a bond, but in the absence of better info, and if I decided that I did not want to do rivets, this is what I would try.
Unread 27-10-2015, 22:35
Nate Laverdure's Avatar
FRC #2363
Buy it in a preformed loop and stretch it to fit over your hub. No fasteners or adhesives needed.
Square-profile o-rings (stack up several in parallel)
Flat bands
(MANY more options if you use urethane instead of nitrile)
Unread 28-10-2015, 00:30
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Scott Kozutsky will become famous soon enough
Our team had really excellent luck using hardware store double sided tape to make drilling and riveting easier and stronger. The tape holds the nitrile in place while you drill and rivet, making it less squirrely. It makes it considerably easier to get a very snug fit against the wheel and it also has the added benefit of reducing the shear load on the rivets quite considerably. We had relatively shallow flanges (performance wheels) and we had a rivet every third with extras where the loop ended. Properly installed, our tread would have held without the tape. It's just much easier with the tape and more secure in our experience.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
Unread 28-10-2015, 00:48
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Flat bands
How much larger should your hub be than the rubber ID, in your experience?
Unread 28-10-2015, 01:19
Mike Marandola Mike Marandola is online now
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
About 30% larger according to this spreadsheet. I'm not sure if it scales up to the 4-6" range though.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 28-10-2015, 08:04
FRC #2363
I've installed urethane replacement tires on a 16" bandsaw. The tires are about 15% undersized. Maybe interpolate between this and the resource Mike linked?
Unread 28-10-2015, 09:29
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Back when I was racing bicycles, I use 3M weather strip adhesive to glue my tires on. It is basically a strong contact cement. Changing the tread will be a bear.
