Re: CIMcoder: Encoder Mount
Correct me if I am wrong but couldn't you use a true-false variable to determine if you were in the high or low gear? Then from there you could a just the way your code reads the encoder.
I would much rather put the encoder wheel side so you don't have to keep track of it/probably easier for repairs as well. |
I prefer having the encoders on the gearbox, as they're more protected that way. We occasionally (around once per year) lose encoders due to insufficient protection/some small mistake that destroys the already-vulnerable encoders. |
Thanks for sharing! |
We printed one of these using our statasys. The holes for the screws for the encoder are just slightly too large to tap them for 4-40. We ended up putting a bit of glue in the hole and then taping it (READ: forcing the screw in). Worked out well.
Overall, a very nice design. |
#7
If you actually end up using it I would love to see pictures. Last edited by Munchskull : 08-11-2015 at 20:21. |
#8
There is a good chance this will end up on our off-season project. If it does I'll post a couple of pictures.
