Go to Post The game is as much a competition of strategies as it is of robots. There is never any one "best strategy." If teams choose to use this as their strategy, find one that will beat them. - srjjs [more]
Unread 28-10-2015, 22:07
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #1072 (MVRT)
Re: CIMcoder: Encoder Mount
Originally Posted by R.C. View Post
You would probably want to measure if the ball or dog is engaged or the change in velocity. I would recommend this over checking against a variable as shifting isn't instantaneous.
I would much rather put the encoder wheel side so you don't have to keep track of it/probably easier for repairs as well.
I feel like for most teams in most situations the minor time lag associated with shifting shouldn't affect them significantly.
I prefer having the encoders on the gearbox, as they're more protected that way. We occasionally (around once per year) lose encoders due to insufficient protection/some small mistake that destroys the already-vulnerable encoders.
Unread 30-10-2015, 12:02
JamesTerm's Avatar
JamesTerm JamesTerm is offline
Terminator
AKA: James Killian
FRC #3481 (Bronc Botz)
JamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to behold
Originally Posted by BBray_T1296 View Post
When I print bolt holes I usually undersize a little and print with extra shells (maybe 4 instead of my typical 2) and then drill it out with a free fit tap drill bit. Steel machine screws easily tap themselves into the hole and make their own thread. Otherwise I will drill a clearance hole for non-threading situations.
It is generally a very easy extra operation that saves the hassle of worrying about print tolerance.
Ah that's a good approach... thanks for sharing.
I've went ahead and uploaded a little camera mounting project I did which illustrates what I do for the holes... I found on my printer to just expand the diameter by about 0.02... the threading pitch works out well enough, and I also experimented with 3D printed screws as well... not sure yet if I'll do that again, but if weight matters... it may be worth consideration.
https://grabcad.com/library/camera-m...-m1011-m1013-1
Unread 03-11-2015, 15:41
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
The more I think about it, the less I think you'd need to measure encoder values *during* shifting. We usually use encoders for auto, and it's not likely that we would shift during auto. Even if we had some sort of fancy always-on gyro compensation, we could probably disable it for a second during the shift.
Thanks for sharing!
Unread 06-11-2015, 00:57
We put our encoders on the gearbox, down stream of the shifting mechanism. This gives us less backlash in our measurement and we don't have to worry about shifting. The accumulated hex backlash due to the clearances that Aren specs is quite large, and the dog engagement also adds to the problem. When you are trying to design a precision autonomous mode, every little thing counts. The best way to design an awesome control loop is to have awesome hardware to control.
Unread 06-11-2015, 08:22
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
We printed one of these using our statasys. The holes for the screws for the encoder are just slightly too large to tap them for 4-40. We ended up putting a bit of glue in the hole and then taping it (READ: forcing the screw in). Worked out well.
Overall, a very nice design.
Unread 08-11-2015, 20:19
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Thank you. Glad that you like it. I actually believe that when I designed the encoder holes I was designing with the intention of using M3 bolts since that was what the encoder was speced for.
If you actually end up using it I would love to see pictures.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 08-11-2015, 22:58
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
There is a good chance this will end up on our off-season project. If it does I'll post a couple of pictures.
