Go to Post Are you confused yet? - Andy Grady [more]
Unread 30-11-2011, 17:10
akeisic's Avatar
akeisic akeisic is offline
Systems and Strategy Mentor
AKA: Andrew Keisic
FRC #4201 (The Vitruvian Bots)
akeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to all
paper: Beach Cities Robotics Clock In System
Thread created automatically to discuss a document in CD-Media.
Beach Cities Robotics Clock In System by akeisic
Unread 30-11-2011, 17:16
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: paper: Beach Cities Robotics Clock In System
How do I get this working in Excel 2003? It currently does not.
Unread 30-11-2011, 19:20
kaliken kaliken is offline
294 Old Fart Mentor...
AKA: Ken S
kaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant future
As you have noticed, the files are in Office 2007 (or later) format. However have you tried using Microsoft's Office compatibility pack to open office 2007 and later files? That may be a process that can work. If you have already tried this and it still did not work, PM Andrew to see what he can do.
2010 World Champions! Newton Alliance Captain: Many thanks to 67 and 177 for the amazing ride
Unread 30-11-2011, 20:14
Doesn't work with file format converters installed in 2003. However, I did try it in 2010 and this is really almost exactly what I need, however I don't really have 2010. I'll PM him to see if there's any way to use it in 2003.
Unread 06-10-2012, 12:53
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Thanks, works great and was easy to set up.
One question, or request, or feature request....
I have it set up on an old laptop, and have it logging into and starting the workbook on boot. Question is that zoom level is automatically set to 119% and seems to be forced in the macros somewhere. For the laptop, I need to set the zoom to something closer to 80% to be full screen. Can you send me a clue, on where I can edit that in the macro, I did a quick scan, and did not see it.
As for the feature request, if this was made a variable from the team configuration sheet, that would others, and make it a little more user friendly.
The sooner we get behind schedule, the more time we have to catch up.
Last edited by tr6scott : 06-10-2012 at 12:56. Reason: ask for the feature request.
Unread 08-10-2012, 12:58
AKA: Ken S
I will let Andrew know about the request as he did the amazing job of setting it all up. As for changing the zoom level, I am not sure exactly where it would be hard coded.
I am glad people are using the system. The clock in system even though it seems like a tough work place type of thing, has really helped us in identifying students who have put a lot of time into the year. In addition it has given us a good understanding of the amount of hours it really takes to build a robot! Since Andrews first version of the software in 2009/2010 We have logged tens of thousands of hours!
Also as an update, one of our other mentors, Peter, did a mass overhaul on our sign in system over the summer. We have now ported it to Python and tied it to our team database system for team registration and contact. If we find the time (we meaning Peter) we can upload it to CD though I am not sure how difficult it would be to remove the hooks to our database.
Unread 08-10-2012, 13:26
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
The Python sign in system is available on GitHub: https://github.com/team294/signinapp. It runs on both Windows and Linux as a PyQt application. Currently it's written to use Python 3 but I'll probably update it soon so it can run on either 2 or 3.
As Ken mentioned, it is currently written to tie into our Django-based team database system (also on GitHub; https://github.com/team294/roster) to pull user information and photos and push timecard records. However, all of the database access code in the sign in application is localized to rosteraccess.py, so it should be fairly easy to adapt it to a different backend (e.g. reading/writing to CSV files).
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 09-10-2012, 08:09
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
Thanks we like excel, as I work in it everyday. When I don't have something else to learn, I will take a look. Thanks for sharing.
I have it working, this is what you need to do. I don't think CD will let me post the new workbook to this this thread. So this is what you need to do if you want to...
In the teams setup sheet, in the row under the "clock out credit" in R9C1 enter the text, "Zoom Level on Open" and in R9C2 enter the value you want, "80" for us.
Open up the VBA Macros (Ribbon bar, view, macros) select any macro click edit. When VBA opens up, on left pane, click "ThisWorkbook" then on the code window select "Open" from the dropdown list. [Another way is to use find, and search the whole project for "zoom"]
At the bottom of the window you will see:
Private Sub Workbook_Open()
    Sheet1.Activate
    ActiveWindow.Zoom = 119
    ActiveWindow.DisplayGridlines = False
    ActiveWindow.DisplayHeadings = False
    Application.DisplayFormulaBar = False
    'Application.DisplayFullScreen = True
End Sub
change the zoom value to:
    Sheet1.Activate
    ActiveWindow.Zoom = Sheet8.Cells(9, 2)
End Sub
Save and close, when you open the sheet next time it will zoom to the value stored in team setup sheet.
Unread 09-10-2012, 19:50
Bob Steele's Avatar
AKA: Bob Steele
I got a copy of this two years ago from your team.
We didn't get a chance to put it in place last year but are working on it right now. With over 60 student members on the team and an additional 15 mentors, we have a bottle neck at the old sign in sheet.
We are attempting to put our Classmate to this use. We retired it as something to use on the field the year we got it...
I will keep you posted about whether it will handle it.
thanks again!!
Unread 14-10-2012, 22:40
akeisic's Avatar
AKA: Andrew Keisic
Glad to see the interest in the sheet. I just uploaded v2.01 with an extra option on the Team Setup tab to set the opening zoom level.
As Ken and Peter have mentioned, it's made life so much easier. We now have students who won't leave unless others do as well to keep his/her hours above others. After using it for a couple years now and have now integrated the sign in application with our team information database. See Peter's post above. It's a bit more work to setup though.
Keep the suggestions coming as the FIRST community is now the driver for more improvements.
Mentor: FRC 4201 - The Vitruvian Bots
Awards with FRC 294 - Beach Cities Robotics
2014: LA FRC Champions
2012: LA FRC Finalists
2011: San Diego FRC Finalists
2010: San Diego FTC Finalists, San Diego FRC Champions, LA FRC Finalist, FRC World Champions
2009: LA FRC Finalist
2008: San Diego FRC Champions, LA FRC Finalist, LA FTC Champions, LA VCR Champions,
2007: San Diego FRC Finalist, San Diego FTC Champions, FTC World Champions
Unread 25-10-2012, 20:53
Brandon Holley's Avatar
We really love the check-in system you guys have put together and are attempting to implement it currently.
For some reason we are having issues reading the barcodes with our barcode scanner we purchased. We did follow the instructions and copied the font into the windows font folder. Excel and the barcode scanner will scan various barcodes we have laying around with no issue (like the barcode for the serial# on our Dell desktops). However, with a black and white printout from our printer, we are unable to get the scanner to register the codes.
Do you have any insight into this type of issue or any suggestions we may be able to try to correct it?
Thanks for the great program.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 28-10-2012, 15:13
akeisic's Avatar
AKA: Andrew Keisic
The first thing that comes to mind is to try a couple different background colors for the badge. If it's sufficiently dark enough, the bar code reader might be picking up the frame of the bar code box as opposed to the bar code itself.
Outside of that I can't think of any smoking gun solution.
Andrew
Unread 28-10-2015, 01:06
This Guy This Guy is offline
FRC #4322
This Guy is an unknown quantity at this point
This looks amazing!!! Team 4322 has been looking into something like this for the team and so far nothing even comes close to it. However, is there any way we can edit the badges or will we just have to make our own? I would like to change the background on them to 1 of 2 images for Students or Mentors/Parents, and is there a way to put our logo instead of just text? Or change the font of the team name?
Unread 28-10-2015, 21:14
FRC #4322
Nevermind, after skimming through the code I was able to fine the comment with a password.
Unread 29-10-2015, 15:48
FRC #4322
-Brando
We are having the same issue. For some reason Excel is adding a "Space" after the code ("*"+content+"*"). I haven't found a way to get rid of it.
