Go to Post The difference between a Tinkerer and an Engineer is that the Engineer will be able to tell you the results before you start. - DonRotolo [more]
Unread 29-10-2015, 15:15
entertainr entertainr is offline
Build Addicted
AKA: Levi
FRC #4522 (Team SCREAM)
entertainr is an unknown quantity at this point
MA3 Value Troubles
I have been trying to read a MA3 analog encoder through a Talon SRX. I was under the impression that the values it outputs should go from 0-360, then reset to 0 upon a full rotation. Whenever I test it though, I'm getting readings from -infinity to infinity like a normal encoder.
I've attached screen shots from begin and periodic tasks, I can add a self-test of the Talon SRX if needed.
ID:	19377  Click image for larger version
Name:	Periodic Tasks.PNG
Unread 29-10-2015, 19:02
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Re: MA3 Value Troubles
"Analog Encoder" counts the overflows in both directions, so you can servo multiple rotations. This is explained in section 16.11 in the Talon SRX Software Reference Manual. Also in section 17.3
If you want your position to be [0 to 1023] and not track overflows, you can select "analog potentiometer" (section 17.2), however unless you can guarantee your mechanism can't turn more than one rotation, this is likely not what you want. For example if you have a PIDF control loop and you are serving to a position, and the mechanism overshoots your MA3 encoder, you would want your control loop to servo back gracefully, instead of seeing a major discontinuity of 1023 => 0.
The 2015 implementation uses Talon SRX raw units for sensor, see section 17 for the details. It's not in degrees.
Documents...
http://www.ctr-electronics.com/talon...ical_resources
