Re: Help - Can't figure out way to connect spool to webbing
Have you considered using an appropriate piece of timing belt, cut down to the circumference of the sheave, then rivet your webbing onto it in such a way that the webbing both holds the ends of the belt fragment together, and grips the webbing for the lift?
Another alternative might be to use a high-strength flexible adhesive (gorilla glue or shoe goo) to do the same thing. Or, of course, both... Edit: and yes, Mike's suggestion of larger flanges is definitely in order! 2nd edit: as you can 3-d print a spool, a totally different solution would be to 3-d print a spool that accepts a COTS metal hub with some bolts, then engages with the webbing, and provides the needed flanges. Last edited by GeeTwo : 29-10-2015 at 21:42. |
Also are you saying to actually glue the webbing onto the spool or glue the belt onto the spool and rivet the belt to the spool? Would either of those work? |
Also, Mr. V is correct in that having a couple of wraps that never come off will reduce the stress on your attachment point(s) significantly. As you have already modified your sheave, your simplest route at this point is to add a couple of wraps of webbing to reduce the end stress. |
Your wheels are on wrong as well.
Oh that is what you meant...
I thought you meant that our wheels were on the wrong side of the chassis. We cant count how many people who have walked in and told us that... After we explained mecanum wheels they got it but... yea. Thanks for catching that though before our programmers go crazy. |
Make sure that you have sufficient space between the spool and the top cross piece to accommodate your webbing once the carriage is raised as high as you want it to go. From how it looks in your first picture (zoomed in on the motor and spool), it looks like you may get only 2~4 wraps around the spool before it all jams against the top cross piece.
You may also want to use something other than nuts as spacers between the cross piece and the gear box. I have noticed that the tolerances on the thickness on hardware like nuts and washers can be quite large. The contact area of the nuts is also quite small so you may want to replace them with a thick plate or a stack of fender washers to prevent crushing the top side of your top cross piece. You will be putting quite a bit of force on two of the four mounting bolts as you raise the carriage, especially when loaded. Over time, this will likely crush the lower side of your cross piece, making the bolts go loose. You may want to make sure your top cross piece is thicker walled material and since it is aluminum, you may want to add steel fender washers or a 1/16 inch thick steel plate to spread the forces out. It may be better to rotate the gear box on it's axis by 90 degrees then attach it to the front and rear faces of the cross piece with two plates (I am assuming that there are mounting holes on the other side of the gear box too). You can then easily get any spacing you want between the spool and the cross piece. The fasteners would then be in shear rather than in compression (and possibly crushing your tubing). Lastly, you may want to add a shallow U-shaped brace between the two vertical posts, about half way up, attached to the outside surface of the vertical posts. We used the same (or similar) carriage wheels on our practice robot and the carriage wheels to slip between the tubes when the carriage is loaded. There is only about 3/16 inch of overlap of the carriage wheels on the vertical tubes so the carriage twisting slightly will pry the two tubes apart and allow the carriage wheels to slip in between the tubes. You may want to grab the two tubes and try spreading them to see how rigid your tubes are. At Robot Remix, this past weekend, the Finalist Alliance Leader robot had two long woodworking clamps to prevent this from happening to their robot ![]() |
#7
Aloha,
What we ended up doing was 3d print the spool and guide. On the spool where the two bolts goes through to assemble the two halves we put in a large enough cut out to accommodate the strapping as well. You just sew the end of the belt to make a small loop for the bolt to go through when you assemble the spool the belt is on. It keeps the belt quite flat when spooling since the loop is below the barrel where the strap winds up. It can feed either direction. The second part is a guide to keep the belt centered while spooling. Though the sides were high enough that it wasn't really necessary. Here is a picture of the spool on the robot, you can zoom and hopefully see. http://www.chiefdelphi.com/media/photos/42355 I will post a picture of just the disassembled spool and update this with the link when it is available. We ran this through two regionals and the champs and never had an issue.. Still working today. Any questions? |
#8
I would recommend using a full belt or chain so that you are powering both the up and down direction.
Gravity does work... just not that well in some situations. You can get belt that you basically cut to length. Then I recommend having the ends be on the carrier portion of your elevator. This loop style is also beneficial as you can put the motor down in the belly thus lowering your center of gravity (which is generally a good thing). |
#9
Howzit!!
The picture has gone through and is now posted.. Here is the link http://www.chiefdelphi.com/media/photos/42415? You can see the recess for the bolt and looped end of the strap. The spool is printed to use the 1/2" hex directly out of the transmission. We basically mated two Vex Pro 2 CIM, 2 speed transmissions together. one used the motors and two speed selection really helped when the load got heavy. The second transmission was setup to shift between a free wheel spin and a one way ratcheting system. We just used a ratcheting wrench and cut a small hole for the reset of the wrench it to stick out of housing. If you are interested I can post pictures of the assembled winch system. Or CAD files if you like. Also as mentioned it would be a good idea to get that motor and spool down into the chassis. Yes the strap will be longer but it will not affect the amount of strapping you need to winch.. Our system was gravity return and with the weight of the tool we never had an issue with the lift lowering when empty. Good luck, Aloha. |
#10
Decided to just wait to comment on this thread until we finished. We chose the first option of tapping the holes and using a soldering iron to burn holes through.
It was a great experience learning how to tap holes and it allowed us to end with a much more robust product. Here is a video of the lift working. https://youtu.be/0oAcXcJqIbg Here are some pictures of the finished spool ![]() ![]() We are going to do some finishing touches like adding the ramp (which is why the motor is not lower in the Chassis and possibly adding intake rollers. Thanks everyone for your suggestions. This is the first bit of success our team has had in years. A lifting robot may not mean much to a lot of you but to us its awesome. There is going to be a reveal video sometime late this week! Last edited by Sperkowsky : 02-11-2015 at 22:03. |
#11
This would be an ideal opportunity to learn about adding something to stop the carriage before it hits the top or bottom, and possibly damaging itself. The most obvious would be to use a limit switch at the top and one at the bottom. Other options include distance measuring devices such as an ultrasonic sensor or a Lidar (that is what we used). Each has it's advantages and disadvantages and this is a good time for your team to learn about them. Once you add the manipulators (arms, claws, hooks, etc.) for picking up the totes, you may find that you will want to relocate your motor so that the spool and strap are centered on the carriage. Otherwise, the carriage may twist as it is lifted, spread the two vertical tubes and become de-railed. Keep up the good work. |
